Date: 14-05-26  Time: 09:59 am
Author Topic: Draper Compression Tester  (Read 2426 times)
humbucker88
« on: 02 September 2013, 03:44:00 pm »
Has anyone used the draper compression tester before? It doesn't actually seem to fit under the frame to use it...
Re: Draper Compression Tester
« Reply #1 on: 02 September 2013, 05:08:40 pm »
is it the push in type.....ive got the screw in thpe with flexible hose....works a treat and is more reliable  ;)
humbucker88
« Reply #2 on: 02 September 2013, 05:57:17 pm »
It's the useless type. Screw in. http://www.ebay.co.uk/itm/130969665378 See the long gold bit on the hose? Well it's a 14mm type, needs the biggest adaptor on it to fit, so now there's a giant gold pole on the end of the tube, which won't fit under the frame to allow it to be screwed in, ridiculous.
