Date: 06-05-26  Time: 07:20 am
Author Topic: Oil Plug beside oil level window?  (Read 10688 times)
bmseven
« on: 01 September 2013, 07:15:08 pm »
Went out for a ride today only to be covered in oil from the little allen cap beside the oil level window.
Tried tightening it but it just fell apart in my hands anyone know what its purpose is/what its called  or where to get one from
Its an allen bolt with a rubber O ring?
Thanks in advance
Tone
Re: Oil Plug beside oil level window?
« Reply #2 on: 01 September 2013, 08:03:22 pm »
Not sure if that exact link is what you need but that website will help you anyway.
bmseven
« Reply #3 on: 01 September 2013, 08:29:19 pm »
Cheers Darrsi bookmarked that one  :)
Still not sure what its for though
Item 8 Plug!
http://www.yamahascooterspares.co.uk/product/yamaha/36Y151890000/plug?uid=0
andybesy
« Reply #4 on: 01 September 2013, 08:44:12 pm »
How much oil came out?
« Reply #5 on: 01 September 2013, 08:51:45 pm »
Any reason why your link opened up on the FZR Genesis page?
bmseven
« Reply #6 on: 01 September 2013, 09:00:25 pm »
Andybesi Quite a lot  of oil spray all down the side and under the bike over the pads :)
darrsi Opens up on FZS600 for me !
« Reply #7 on: 01 September 2013, 09:37:51 pm »
How strange?
« Reply #8 on: 01 September 2013, 10:42:37 pm »
It is called an oil gallery plug and plugs the end of the main oil gallery which supplies oil under pressure to the crank bearings.There is also one on the other side directly oppisite. It can be used to check the oil pressure by removing the plug and attaching an oil pressure guage to it. When you replace the plug, replace the O ring also and tighten it to 8 Nm and do not overtighten it as it is easily broken.
Lez72
« Reply #9 on: 02 September 2013, 02:48:38 am »
Can this plug be removed without draining the engine oil ? I need to change mine too  ;)
bmseven
« Reply #10 on: 02 September 2013, 12:18:00 pm »
Unfazed - Thanks for the info you learn something every day :)
Lez72 - I have drained the oil and changed the filter but with the plug out oil was still leaking out. The plugs location is slightly above the window but obviously as unfazed says an oil gallery without draining  all oil a minimal loss seems unavoidable less so if your quick
Parts ordered from dealer
Yamaha plug Part No/ 36Y151890000  £12.04
Yamaha O ring  Part No/ 932101662900 £1.81
Many thanks everyone
Dead Eye
« Reply #11 on: 02 September 2013, 12:19:22 pm »
You MIGHT be able to get away with doing the right hand side one next to the window if you put the bike on the side stand - you can remove the clutch cover safely doing this so...
« Reply #12 on: 02 September 2013, 09:28:22 pm »
As Dead Eye says you should be able to change the right one with minimal oil loss with the bike on the side stand. The left side could be changed the same way if you get some way or some one to support the bike tipped over to the right.
DanielT
« Reply #13 on: 23 December 2013, 06:39:58 pm »
This is extremely true.  Now supposing a complete donut overtightened it, and the head snapped off, leaving the bolt inside.  How would aforementioned donut remove it?  All ideas gratefully received!
Edit: Trend Pro Grabit. £18 from screwfix solved the problem.  Relief!
bmseven
« Reply #14 on: 23 December 2013, 08:34:23 pm »
The head fell apart on mine but the recess goes into the engine so was able to unscrew with an allen key
DanielT
« Reply #15 on: 23 December 2013, 08:53:17 pm »
half of the allen key recess was gone too, so there wasn't quite enough grip. tried to epoxy the bit to it first, but no joy.
Thanks for the part numbers, I've ordered them.  :thumbup
« Reply #16 on: 23 December 2013, 09:38:29 pm »
So should we all change ours before we all suffer the same.
Cant see why the plug is so expensive tho.
Having just changed the coolent - when you remove the drain plug nothing comes out untill you take off the filler cap- wouldnt this be just the same, or even less so as the oil is thicker and is not so far above the draining hole and so dosent have a head of pressure above
« Reply #17 on: 23 December 2013, 09:45:20 pm »
Don't touch it.........in fact, pretend you never saw this post.
richfzs
« Reply #18 on: 23 December 2013, 10:03:18 pm »
fazersharp, this tells you all you need to know...
His Dudeness
« Reply #19 on: 23 December 2013, 10:13:58 pm »
It's sure to be siezed. you'll have to drift it out with a size 4 hammer
His Dudeness
« Reply #20 on: 23 December 2013, 10:16:25 pm »
You come up with some great theories fazersharp
« Reply #21 on: 24 December 2013, 10:57:05 am »
Quote
I have been told before but with different words, and not so generous as yours.
Sooo im not to touch it then am I
bmseven
« Reply #22 on: 24 December 2013, 11:28:34 am »
No oil comes out when you remove the plug (maybe a dribble) but mine was misting when running
His Dudeness
« Reply #23 on: 24 December 2013, 12:12:29 pm »
Quote
:lol :thumbup
richfzs's schematic has the answer :lol
