Date: 14-05-26  Time: 10:56 am
Author Topic: rear wheel jumping noise  (Read 3932 times)
psyfi_1
« on: 30 August 2013, 08:17:11 pm »
okay the chains slapping about had full engine rebuild so its not the engine........ can the reaer wheel being out of alignment do this
Re: rear wheel jumping noise
« Reply #1 on: 30 August 2013, 08:20:44 pm »
As you are riding, or with bike on centre stand?
ChristoT
« Reply #2 on: 30 August 2013, 08:27:35 pm »
If on centre stand, normal, don't panic.  :)
If riding - chain tension?
tat1959
« Reply #3 on: 30 August 2013, 08:45:58 pm »
Check all the links on the chain, if there are any tight links they make a clunking noise as it goes round the small front sprocket and you can usually feel it jumping through the foot rests as you ride.
« Reply #4 on: 31 August 2013, 09:08:44 am »
I replied within 4 minutes, that was 13 hours ago, it can't be that bad?  :lol
psyfi_1
« Reply #5 on: 31 August 2013, 10:27:09 am »
cheers mate it does do it on the centre stand and a little bit so i will get the rear tyre adjusted chee[size=78%]rs mate[/size]
« Reply #6 on: 31 August 2013, 10:32:38 am »
No weight on rear wheel when on centre stand, it's the momentum of the wheel trying to overtake the chain causing the jumpy effect.
Totally normal.
Don't stop it by over tightening the chain, or you'll really have problems.
His Dudeness
« Reply #7 on: 31 August 2013, 11:12:39 am »
They all jump on the centre stand. Only adjust it if it's out of spec and follow the service manual instructions in the download section. What work did you have done in the rebuild? Seems like not too many people rebuild fazer engines. I can't remember seeing threads on here anyway.
psyfi_1
« Reply #8 on: 31 August 2013, 01:21:33 pm »
well yes new gear box piston heads and crankshaft spockets frot rear and chain
 but yeh mission and lot of money
« Reply #9 on: 31 August 2013, 01:23:00 pm »
Blimey, what happened there then?
psyfi_1
« Reply #10 on: 31 August 2013, 02:48:07 pm »
well your right adjusted the chain and know its fine doesstill jump on center stand but nothing when ive got wait on it
ChristoT
« Reply #11 on: 31 August 2013, 02:51:59 pm »
As Mr Yamaha intended.  :thumbup
