Date: 14-05-26  Time: 16:01 pm
Author Topic: Tyre pressures for BT21`s ?  (Read 5351 times)
AN GOF
« on: 30 August 2013, 05:59:45 pm »
Forgot to ask the old owner when i bought my fzs600, whats the front and rear pressure supposed to be ?
Dead Eye
Re: Tyre pressures for BT21`s ?
« Reply #1 on: 30 August 2013, 06:06:49 pm »
Usually down to personal preference and rider weight more than anything
I'm currently running 36F / 42R but I'm a relatively heavy rider
« Reply #2 on: 30 August 2013, 06:16:09 pm »
 :agree
stevierst
« Reply #3 on: 30 August 2013, 06:26:09 pm »
I used to run 34/40 and I'm 13.5 stone. They did ok at that.
Punkstig
« Reply #4 on: 30 August 2013, 07:22:06 pm »
36/40 wether fully loaded or not, only time I do different is trackdays!
« Reply #5 on: 30 August 2013, 07:49:32 pm »
What pressure would you use on a track?
AN GOF
« Reply #6 on: 30 August 2013, 08:00:40 pm »
Thanks guys, im running 32/40 atm so will stick with that i rekon  8)
Skippernick
« Reply #7 on: 30 August 2013, 08:08:29 pm »
I have bt23s and used to rum 36/40 now dropped them down a bit to 34/38.
Feel its given me a bit more cornering confidence, might just be pyshcological.
BluprintZ
« Reply #8 on: 30 August 2013, 10:27:10 pm »
I've just got a BT23 for the front and a BT21 for the rear, been advised to run them at 33psi front and 36 rear, more tread on the road.
I'm around 12 stone.
G ; )
Punkstig
« Reply #9 on: 31 August 2013, 12:02:45 am »
First session I went with a recommended 30/30 cold which sucked balls, 2nd session and all sessions after were 32/34!
« Reply #10 on: 31 August 2013, 08:41:09 am »
I s'pose heat, expansion and a nice even flat service majorly changes things.
30/30 must've felt like a golf cart!
Punkstig
« Reply #11 on: 31 August 2013, 09:34:00 am »
Yeah, that's why you have to lower them for track, the heat generated is incredible which rises the pressure considerably.
Only takes a couple of laps to warm up but those first ones do feel naff- slow and hard to turn in, by the end of the first session the feeling wasn't 100%, still needed to muscle the bike over for corners, so I knew I needed to increase the rear slightly. Set them to 32/34 for the next session and it felt awesome so kept it at that for the rest of the day!
« Reply #12 on: 31 August 2013, 09:46:39 am »
Unfortunately i seem to have a slow air leak on my rear, so i range from 42 to 36 over about a week.
Thinking about it, midweek probably feels best, which is probably 38 to 40.
Luckily i have access to an airline at work so although slightly irritating it's not a major.
Hedgetrimmer
« Reply #13 on: 31 August 2013, 10:42:44 am »
I have Wednesdays off, so that would work for me!  :rollin
His Dudeness
« Reply #14 on: 31 August 2013, 11:04:02 am »
Think mine are 32/36
