Date: 14-05-26  Time: 17:59 pm
Author Topic: er theres no drive from the front to the rear wheels  (Read 3399 times)
psyfi_1
« on: 29 August 2013, 10:35:42 am »
okay my engines ticking over fine but put into gear and theres no torque or drive to the rear wheels its spins slightly but when you pull the clutch in the wheel stops moving am i right to say this is the clutch????
Dead Eye
Re: er theres no drive from the front to the rear wheels
« Reply #1 on: 29 August 2013, 10:45:40 am »
Sounds like the clutch isn't adjusted correctly - have you just done a rebuild or something?
Best to adjust it from the front sprocket cover before adjusting at the lever side
« Reply #2 on: 29 August 2013, 11:35:32 am »
history ?
psyfi_1
« Reply #3 on: 29 August 2013, 11:38:05 am »
yes but i have adjusted the clutch cable side all the way in all the way out makes o difference if the toque settings was done on the clutch plate thats sits on top of the basket (ie) springs and the one nut that holds on the basket.......
psyfi_1
« Reply #4 on: 29 August 2013, 11:39:05 am »
sorry thats meant to say havnt done the torque setting
Dead Eye
« Reply #5 on: 29 August 2013, 11:43:03 am »
I had a similar issue with mine, the pressure plate MUST seat correctly in the spines or it won't function properly (this is how I broke mine :( )
Also, check to make sure that the plates are in the correct order and that the judder spring is in the right place with the correct plate sat around it - one of the friction plates has a larger internal diameter to accommodate it. Shouldn't take too long to whip it all off and check
Edit: Also, this topic should be moved the FZS 600 Forum ;)
Pat
« Reply #6 on: 29 August 2013, 12:09:34 pm »
As it's a 600 have you checked the front sprocket?
psyfi_1
« Reply #7 on: 29 August 2013, 12:13:58 pm »
what do you mean have i checked the front sprocket i have recently replaced its and it was torque upped and the washer that bends over the nut was put in properly put on
psyfi_1
« Reply #8 on: 29 August 2013, 12:18:23 pm »
also sorry i thought this was on the right forum where should i put messages like this
Dead Eye
« Reply #9 on: 29 August 2013, 06:40:26 pm »
Don't worry, its fine :)
Did you strip down the clutch?
psyfi_1
« Reply #10 on: 30 August 2013, 11:25:41 am »
yeh yesterday i did and now its sorted i put the the pin that the clutch plate sits on wrong the bar going from the cable side had pushed the ballbearing and pin through to far so when i put the clutch plate back on it was to far out............... thankyou for ur help
Dead Eye
« Reply #11 on: 30 August 2013, 01:18:09 pm »
You're welcome, glad its sorted :)
Stripped mine down at least a dozen times trying to get it right when I had my issue :P
