Date: 26-05-26  Time: 14:34 pm
Author Topic: Balance Carbs  (Read 5336 times)
fazersteve
Balance Carbs
« on: 11 August 2013, 11:40:44 am »
Balancing my carbs for the first time. When I reset the TPS plus my one reads 3000 revs.
Even when I move TPS switch it stills reads 3000 revs. And not 5000 as per guide.
mickvp
  • Global Moderator
Re: Balance Carbs
« Reply #1 on: 11 August 2013, 12:13:06 pm »
A quick search turned up this:
Quote
If you plugged it back in and it read 3000rpm then that is saying a faulty TPS (or faulty wiring to TPS but unlikely).
If it was positioned wrong it would read 0rpm or 10,000rpm and would need adjusting.
If all was correct it would read 5000rpm.
Faulty speed sensor would read 4000rpm.
Re: Balance Carbs
« Reply #2 on: 11 August 2013, 12:54:57 pm »
I know this sounds daft but you did plug it back in didn't you?
fazersteve
Re: Balance Carbs
« Reply #3 on: 11 August 2013, 02:07:09 pm »
Manage to set at 5000 revs. And once I found where ever thing else was manage to set carbs.
The long reach screwdriver from Tool station helped make the job so much earlier.
Luckily I was not changing myself at a hourly rate. Next time should be a breeze.
Thanks again for all the help
His Dudeness
Re: Balance Carbs
« Reply #4 on: 11 August 2013, 03:37:19 pm »
I've found that the first time you do anything it rarely goes 100% smoothly :lol But that's what learning is all about!
Soapy
Re: Balance Carbs
« Reply #5 on: 11 August 2013, 06:05:07 pm »
Hi Steve could you give me details of the screwdriver you bought. When I did my balance recently I struggled to adjust the RH screw as the shaft of my screwdriver was a bit thick
Re: Balance Carbs
« Reply #6 on: 11 August 2013, 06:38:05 pm »
I ended up buying two screwdrivers as the first one i got online had a hex shaft that didn't fit down that gap on the right.
fazersteve
Re: Balance Carbs
« Reply #7 on: 11 August 2013, 10:04:29 pm »
Hi Soapy,
Bought these two from ToolStation
http://www.toolstation.com/shop/Hand+Tools/Screwdrivers/Extra+Long+Screwdriver+PZD+1x450mm/d10/sd80/p82330
Wasn't sure what one would be best so bought both. At 450mm long they work a treat.
jrfunkygibbon
Re: Balance Carbs
« Reply #8 on: 28 March 2014, 11:01:49 pm »
which size pozidrive did you buy , was it the #1  or #2? i  know it helps to have a narrow tool
Re: Balance Carbs
« Reply #9 on: 29 March 2014, 05:54:28 am »
The #2's okay, not brilliant, gotta be round, but i use a small flat blade as well for the adjuster on the right, much easier.
Arunmax
Re: Balance Carbs
« Reply #10 on: 29 March 2014, 08:19:03 am »
Lez72
Re: Balance Carbs
« Reply #11 on: 29 March 2014, 12:25:51 pm »
Arunmax
Re: Balance Carbs
« Reply #12 on: 29 March 2014, 09:00:03 pm »
