Date: 14-01-26  Time: 03:06 am
Author Topic: 12mm front brake caliper bolts  (Read 9114 times)
Sealion127
« on: 02 August 2013, 03:41:37 pm »
hi , anyone know where i can get 4 from , seen some on ebay but there £20!!, mine were seized on and rounded off , took a hammered on 11mm socket to shift them  .
cheers in advance
chris
Re: 12mm front brake caliper bolts
« Reply #1 on: 02 August 2013, 03:58:09 pm »
Always helpful if you list what year of bike you have in your profile, but i'd imagine they're all the same. (no.25 & no.14, but they are the same bolt and part number)
http://www.yamahamotorcyclespares.co.uk/spares/epc2.asp?modelID=9656&PageiD=30&m=YAMAHA+FZS600+Fazer+FRONT+BRAKE+CALIPER&uID=0
Dead Eye
« Reply #2 on: 03 August 2013, 12:22:43 am »
You can find the size and thread pitch from the workshop manual and then just buy them on eBay - I did this recently for the two rear caliper mounting bolts :)
The download is here http://foc-u.co.uk/index.php?action=downloads;sa=view;down=8
The Front Brake caliper bolts should be M8 x 1.25
Unfortunately it doesn't show length BUT that is by far the easiest thing to measure :P Just remember that length is from the base of the bolt head to the end of the thread (so basically doesn't include the bolt head)
mars696
« Reply #3 on: 03 August 2013, 10:41:08 am »
Because i recently change them,the bolts are M10 x 1.25. The manual says M8 but its wrong.
I used 10.9 metric(which is 8 grade american).DOnt use soft bolts there! ;)
Hope it helps! :)
Hedgetrimmer
« Reply #4 on: 03 August 2013, 10:44:21 am »
Don't these bolts have to be of a certain tensile strength?
Dead Eye
« Reply #5 on: 03 August 2013, 11:57:25 am »
Hope it helps! :)
Really? I thought the rear were M10 and the fronts M8 especially since they take a different socket - at least that's the case on my bike :|
I'll check in a minute as I'm working in the garage today on the bike anyways :)
Hedgetrimmer
« Reply #6 on: 03 August 2013, 12:51:56 pm »
Don't want to harp on about this, but I think it's actually pretty important. I believe the torque settings on these bolts are quite high, that's one reason for the tensile rating requirement. Also, if I remember right, they need to be Loctited in place when you refit them.
mars696
« Reply #7 on: 03 August 2013, 01:01:57 pm »
Nick,
If i remember well the oem bolts are 8 grade,wich is the equivalent of 10.9 in metric system.
Of cource we can use titanium bolts :D  but the price is prohibitive. :'(
Hedgetrimmer
« Reply #8 on: 03 August 2013, 01:33:48 pm »
I just wanted to be sure that people don't just use any old bolts as the discussion here seemed to be more about sizes with no mention of other requirements. I know you'd already mentioned this mars696, but wanted to make sure people picked up on it. I've got nothing better to do, sorry!
mars696
« Reply #9 on: 03 August 2013, 01:36:47 pm »
You are right,safety first!!! :)
Dead Eye
« Reply #10 on: 03 August 2013, 01:42:23 pm »
Well, my results were unhelpful... I forgot that the previous owner was a bit mad and so I have three different sized hex bolts holding my calipers on - 1x 14mm, 1x 13mm and 2x 12mm
If nothing else, my bike has character...
« Reply #11 on: 03 August 2013, 01:54:32 pm »
No need to Loctite them, if they're torqued correctly they're going nowhere.
Hedgetrimmer
« Reply #12 on: 03 August 2013, 01:54:45 pm »
Nick,
 :rollin Aaaaaagh! :rolleyes :'( :lol
Sealion127
« Reply #13 on: 03 August 2013, 02:41:26 pm »
thanks for the help and advice , i will order some titanium ones i think .
