Date: 07-05-26  Time: 16:25 pm
Author Topic: Swing arm removal advice  (Read 2940 times)
bellycgb
« on: 01 August 2013, 07:10:31 pm »
I need to remove the swingarm, the haynes manual is saying you need to remove the rear suspension  :eek  i didnt think that was necessary? can anyone point me an idiots guide or explain how to do it?
many thanks
bellycgb
Re: Swing arm removal advice
« Reply #2 on: 01 August 2013, 07:25:16 pm »
Cheers darrsi was on the mobile its a git to navigate the web on it lol
Dead Eye
« Reply #3 on: 01 August 2013, 08:24:47 pm »
You only need to remove the lower linkage from the rear shock, its not hard to do at all and only requires a socket set. It's much more difficult getting the main swingarm bolt out. I went through every size of socket I had and ended up buying one which still didn't fit - it seems to be a really awkward size / fit
From what I can tell, it should be 23mm? People can feel free to correct me on that - but the 23mm socket I bought ended up having an external diameter too large to fit in to the recess. I ended up giving up on the pursuit so can't offer much more advice
Skippernick
« Reply #4 on: 02 August 2013, 12:01:02 am »
In the guide it says this process destroys the pivot arm bearings, you can't do this process just to regrease everything then?
reillypadraig
« Reply #5 on: 02 August 2013, 09:05:14 am »
I went to remove my pivot bar and after 2-3 turn it started to get seriously tight so I said to f€&k with that and tightened it back in, no point causing another problem.
Not sure if it does destroy the bearings
Foxwood
« Reply #6 on: 02 August 2013, 09:30:35 am »
I took it off with the help of a standard Bahco -tool set, cleaned + greased everything and put it back on. Haven't had any problems since (done almost 3000 km).  :rolleyes
« Reply #7 on: 03 August 2013, 12:30:47 am »
The sleeve slides out without damaging the bearings (provided you take care not to introduce grit) so you can regrease them easily enough. The bearings are a tight fit in the swing arm and get wrecked if you have to drift them out, but you'd normally only be doing that if they're knackered anyway.
Skippernick
« Reply #8 on: 03 August 2013, 08:45:17 pm »
Ok thanks fazerider.
Daved and Confused
« Reply #9 on: 05 August 2013, 11:37:15 pm »
Can't remember the sizes at the moment but my sockets are Britool and they fit fine in the frame recess and obviously onto the nut and pivot shaft.
