Date: 18-05-26  Time: 17:55 pm
Author Topic: electrical test/ volt meters ?  (Read 6543 times)
snapper
« on: 24 July 2013, 12:56:12 pm »
Ok after some advice here
 I want to get myself a test meter , But I know nothing about them , and I do mean nothing How to use one included !
so Im looking for something basic but realiable it wont get much use so I dont want to spend a fortune , but equally I dont want some thing thats going to brake or fail after a little while .
also need to be idoit proof ! and have basic instructions !
please if you can post a link to which ever one you'd recomend ?
Thanks people
clayt74
Re: electrical test/ volt meters ?
« Reply #1 on: 24 July 2013, 01:06:03 pm »
I personally have an expensive fluke Meyer but that is cos of my profession.
To be honest you couldn't go wrong with this one for a tenner.
http://mobile.maplin.co.uk/module.aspx?moduleno=44679
garyb
« Reply #2 on: 24 July 2013, 01:18:08 pm »
The fluke are expensive alright but I think they are worth it if you can afford one or as you say need for work etc. Nice finish on them too and very sturdy.
I'am a lazy bugger so love the fully automatic function on mine, saves me having to mess around looking for the appropriate setting or range  :)
Nowt wrong with some of the cheaper ones out there either, I had an old $10 one from Sears Roebuck in US for years and it was a great yoke.
snapper
« Reply #3 on: 24 July 2013, 02:34:42 pm »
Garyb I like the idea of the fully automatic function !
 do you have  a link to which one would be best as looking at the fluke Meyer site doesnt help much
 this will be for mostly bike and car use but also to lend out to friends ect
 cost could be any isuue but that does realy depend on how many £££££s we are talking ?
snapper
« Reply #4 on: 24 July 2013, 02:54:40 pm »
from what I can see the fluke ones seem to go price wise from around £80 bit rich but not impossible to nearly £600 ouch !
maybe maplins £10 is the way to go lol
garyb
Davebo
« Reply #6 on: 24 July 2013, 03:25:36 pm »
Having a continuity (connections test is useful for tracing faults).
I think I got mine from Machine Mart but Maplin is a good option. Screwfix ? Toolstation ?
snapper
« Reply #7 on: 24 July 2013, 03:26:31 pm »
ok Had a quick look about and found this
http://www.ebay.co.uk/itm/NEW-Fluke-113-True-RMS-Digital-Utility-Multimeter-/290934103994?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item43bd061fba#ht_4322wt_932
Gary as far as I can tell its the same ?
Clayt I understand that the maplin one would probably do the job but I woulder if the idiotic fubbelings and abuse it would get at my hand would wreck it , I would rather buy something that will last a life time if I can can I have your thoughts on this ?
Ebme Geek
« Reply #8 on: 24 July 2013, 03:30:22 pm »
I speak as a person who has expensive stuff for medical electronics and cheaper stuff for auto's & boats
The one clayt74 points out above would be totally adequate for the type of use you mention - nothing wrong with that
at a similar level,   >   Note neither has ac current measurement - but you may never need it (both got dc current)
CPC do a Tenma 72-7770 for £7   http://cpc.farnell.com/tenma/72-7770/digital-multimeter/dp/IN04414
or if you would like one that auto ranges so that you only have to select the right function and make sure you have the leads in the right holes (don't forget that bit)
CPC do the Tenma 72-7765 for £13   http://cpc.farnell.com/tenma/72-7765/digital-multimeter/dp/IN04413   :D
this one also got ac current
That's the one I would probably recomend
garyb 's meter looks simple to use but does not have any current measurement without an optional current clamp.
Flukes are nice, I use one, but I think you pay for the name
hope that helps
Steve
clayt74
« Reply #9 on: 24 July 2013, 04:53:42 pm »
yep I have to agree with ebme, most of the cost of a DMM is down to how accurate it is over all of the functions it can perform.
yes auto ranging is a good feature (especially when investigating circuits you are unsure of). in terms of robustness some of the cheaper ones are probably more resilient than the expensive ones. for the type of thing i think you going to be using it for i.e. bike electrics and general DIY i would look for something in the £20- £30 region.
all i think you need is DC volts and Current, AC volts and current, continuity/resistance also Diode/voltage drop can be useful on some bike circuits. I think you would do well to pop into maplin and have a chat with them, they will give you everything you need (but dont let them oversell to you)
good luck
JZS 600
« Reply #10 on: 24 July 2013, 04:56:25 pm »
Maplins, try them out,, cheap and work well
BBROWN1664
« Reply #11 on: 24 July 2013, 07:25:07 pm »
I have a Fluke meter that is around 20 years old. The last time it was calibrated was about 15 years ago and that was the last time I believe the battery was changed too (unless they didn't bother). Great meter butall I need now is a £10 jobbie from Maplins as all I do, like most people is check the odd car/bike battery and check to see if mains voltage is on something or not. Accuracy is not important to me or most people, a simple bulb would do.
AdieR
« Reply #12 on: 24 July 2013, 09:26:20 pm »
Fluke's are nice yes, but eye-wateringly expensive (I've got a 289 for work) - for those using it to earn a living and using it day-in, day-out, cost is less of a factor.
If you're simply doing odd jobs on car / bike, have a look in your local hardware / DIY store for something like Draper which is more cost-effective. Halfords sell Gunson gear which will probably be decent enough for the money (never used Gunson stuff, but it always seemed to have a good rep).
If you've got a City Electrical or Edmunson Electrical outlet nearby, the sometimes have decent, inexpensive testers that are worth a look.
simonm
« Reply #13 on: 24 July 2013, 09:31:33 pm »
I don't think there is such a thing as an idiot proof multimeter.  Unless you're electrically competent they're only good for telling if you have a circuit and/or voltage going through a circuit.
I mainly use mine on the "squeel if there is a circuit setting" and sometimes on the 12/24/240v test.
If you know nowt about multimeters just buy a cheap one, then go back at a later date if/when you need to IMO.
AdieR
« Reply #14 on: 25 July 2013, 07:29:41 am »
This for £24 is probably the simplest of testers, but it'll cover most car / bike / household jobs with voltage indication via LEDs (indeed, I have a Megger one that I keep with the bike because it takes up hardly any space) http://isswww.co.uk/VoltageContinuity-Probes/Fluke-Testers/Fluke-T90/
No current measurement, but current is a seldom used function in my experience (industrial testing apart); for domestic stuff, it's simply verifying the presence or absence of a voltage that matters (rather than knowing the actual numerical voltage), plus it has continuity (those 2 functions will see to most jobs).
simonm
