Date: 01-04-26  Time: 16:55 pm
Author Topic: TYRE /FORK ? PROBLEM  (Read 2757 times)
jason1
« on: 14 July 2013, 05:20:01 pm »
Hi all think i have a FORK issue , firstly my front tyre is wearing just of centre to the right ( sort of dipped ) . Front forks are soft but dont feel any softer than normal , no leaking oil , but front end isnt great over bumpy roads . Lots of bouncing and really not feeling the confidence through the twisties . Checked bearing in wheel/head and all seems fine , no play , knocking or catching anywhere . Have no history regarding fork oil change and i was thinking of changing anyway to thicker stuff as im no light weight . Has anyone come across this before ? or ideas. All ideas would be great  ;)
Hedgetrimmer
Re: TYRE /FORK ? PROBLEM
« Reply #1 on: 14 July 2013, 05:24:58 pm »
Front tyre wear to right of centre line is normal in UK. Due to camber of road (rising to road centre).
bwizz
« Reply #2 on: 14 July 2013, 05:28:42 pm »
My first 98 600 ,had a lot of lost travel in the front forks, which I suspected that the springs  had become compressed. bike also bottomed out quite easily on braking I never got round to resolving this issue,
probably lots of info on the forum re fork oil. I can't see that it should deteriorate really but a possibility
stevierst
« Reply #3 on: 14 July 2013, 05:51:22 pm »
Perfectly normal in UK. Roundabouts and road camber! When I fitted bt021's it was a lot worse!
jason1
« Reply #4 on: 14 July 2013, 07:14:46 pm »
Cool thanks for info , guess new tyre will sort . As about 2mm on worn part , plastic here we go again :'(
bwizz
« Reply #5 on: 14 July 2013, 08:04:17 pm »
Another weird fault I had on my 600 was that when fitted  with a bt21 there was a helish rumbling noise at the front . I refitted the same tyre to my thou there was no tyre noise, Considereing that the 600 has a noisy end can and the tyre noise could be heard above it ,is to say the least very strange
« Reply #6 on: 14 July 2013, 08:09:43 pm »
I changed my fork oil to 15w and i prefer it much better than the 10w, it gives the front a more solid, controlled sort of feel to it.
stevierst
« Reply #7 on: 14 July 2013, 10:02:30 pm »
Ill second that, mine did the same, a very bad tyre imho, hence why they changed it quickly into the bt023
Frosties
« Reply #8 on: 15 July 2013, 07:37:31 am »
Hmmmmm, thought this rumbling was just MY tyre. All gone when changed and it had about 4mm left.
