Date: 03-04-26  Time: 10:36 am
Author Topic: Oil light, which wire?  (Read 1662 times)
reillypadraig
« on: 14 July 2013, 08:26:08 am »
Just wondering if anyone knows which exact wire it is for the oil light in the main white junction under the tank,
Ill explain, simply I was removing the whole from fairing and the whole lot sometime ago now, but I did plug out the wire in the junction box under the tank to remove the clocks completely, when I plugged all back together I lost indicators lights dash lights fuel light, so checked the big white connector and its corroded to hell inside, half the little needles are broken or gone, so I put it back together and tightened it with a cable tie and low and behold everything works, except the oil light,
Just wondering without having to bollox round tracing wires tru the frame and loom does anyone know the exact wire?
clayt74
Re: Oil light, which wire?
« Reply #1 on: 15 July 2013, 10:55:39 am »
looks to me like its the Black and Red wire that is towards the middle of the connector on the bottom row.
good luck
reillypadraig
« Reply #2 on: 15 July 2013, 11:26:08 am »
Thanks! If I can find the adjacent wire on the far side that its meeting and get a long straight connector it should work, one way to find out is just hit the kill switch and press starter button eh?
