Date: 08-04-26  Time: 19:36 pm
Author Topic: disabling egr valve  (Read 3063 times)
esetest
disabling egr valve
« on: 13 July 2013, 06:54:38 pm »
 I am not a mechanic but was wondering .Is it possible to tell when an egr valve is open or shut without removing it , wondering if I were to disconnect it when its shut , then took it for a run and it was ok then that would confirm whether the valve was faulty or not . any advice much appreciated .
BBROWN1664
Re: disabling egr valve
« Reply #1 on: 15 July 2013, 08:43:19 am »
EGR valve?
Are you talking about on a car or do you mean the EXUP valve on a Yamaha exhaust?
stevierst
« Reply #2 on: 15 July 2013, 09:07:14 am »
Or do you mean the AIS valve on a gen 2?
ferritt
« Reply #3 on: 15 July 2013, 07:09:48 pm »
If its a car egr valve you're talking about then either buy (ebay) or make a blanking plate. Sometimes the ecu will pick up that its been blanked off and put the engine management light on, sometimes it wont. Either way though as a result you'll know whether the egr valve is knackered or not.
esetest
« Reply #4 on: 16 July 2013, 10:19:10 pm »
Yes , I was talking about the egr valve on the car , got a new one from vauxparts for £37 , replaced it today , running much better ,didn't feel like it was missing  , but sometimes when you decelerate instead of idling at about 750rpm it just drops to 500 rpm and then cuts out , then it struggles to start . Gonna  clean the throttle body next , see how that goes then , maybe get a coil pack from scrapper .
locksmith
« Reply #5 on: 17 July 2013, 09:44:20 am »
MAF sensor?
locksmith
« Reply #6 on: 17 July 2013, 09:47:43 am »
Have a look on the web and see if you can disable/remove the egr valve. It puts dirty exhaust gases back through your engine, just what the fresh oxygen needs to burn properly!!! and soot up the engine so it doesn't run properly  :\
esetest
« Reply #7 on: 17 July 2013, 10:19:42 pm »
Whats a MAF sensor .
BBROWN1664
« Reply #8 on: 18 July 2013, 08:49:09 am »
Mass Air Flow. Sits between the airbox and the intake chamber normally and gets dirty/fails with age.
esetest
« Reply #9 on: 18 July 2013, 10:04:32 pm »
Thanks to everyone for the advice , got a feeling its the ecu , I was told to test the voltage on the control circuit of the 2 purple relays in the engine compartment - 17v both sides , I had a couple of advisories at the last mot which will probably be expensive , so although she has been a good runner for the last 3 years ,time to get rid before she turns into a money pit .
