Date: 07-05-26  Time: 13:02 pm
Author Topic: What a #osser!  (Read 4827 times)
Slimted
What a #osser!
« on: 13 November 2011, 06:23:44 pm »
Finally got bike back together. She started, sounded a bit rough. I thought must need a bit of a run....... Dont mistake fuel problem for timing problem I said to myself but carried on! Only later when oil was coming out of the exhaust drain hole did I think somethings not right. Ah well, hole in no 4 piston, start again. Note to self- double double check timing....
Sunny Intervals
Re: What a #osser!
« Reply #1 on: 13 November 2011, 07:44:13 pm »
sounds like you rushed yourself  :'(
I always spin the engine a fair few times on the spanner before I feel safe about the timing.
Was the tensioner working correctly and did you make sure that the chain was taut on the opposite side to the tensioner.
All simple checks but easily overlooked when in a rush to get the motor running before you run out of light/need bike for work tomorrow and a mirade of other reasons  :\
Slimted
Re: What a #osser!
« Reply #2 on: 13 November 2011, 08:19:04 pm »
Yeah, rushed it as you describe..... Will take more time next time. Engine half stripped again!
b3tarev3
Re: What a #osser!
« Reply #3 on: 13 November 2011, 08:48:54 pm »
Ouch!
mickdel
Re: What a #osser!
« Reply #4 on: 30 November 2011, 01:59:15 pm »
double ouch!  have you got the replacement parts yet?
BIG MAC
Re: What a #osser!
« Reply #5 on: 30 November 2011, 11:08:34 pm »
Not so ouch....still have an engine sitting behind my shed ...with a good head and pissed-ons
Slimted
Re: What a #osser!
« Reply #6 on: 01 December 2011, 06:17:20 pm »
Nearly rebuilt (again). I got new top end from DK in Stoke(ish). I am going to take plenty of time to get timing right!
Any top tips much appreciated...
Sunny Intervals
Re: What a #osser!
« Reply #7 on: 01 December 2011, 09:05:43 pm »
Just what I said above really,
Spin the engine a few times on the spanners checking the timing marks again after each full rotation  :thumbup
BIG MAC
Re: What a #osser!
« Reply #8 on: 01 December 2011, 09:38:11 pm »
Turn the engine on the spanner (and without plugs in)  and the cam cover off....in the normal direction of rotation..use an oil can on the cam lobes then check cam chain tension (both sides)
Re: What a #osser!
« Reply #9 on: 02 December 2011, 12:42:58 am »
Did you find a full set of bits after the mishap? If there are any bits of the jigsaw missing it'll be worth double-checking they didn't end up in the sump to cause problems later.
Slimted
Re: What a #osser!
« Reply #10 on: 03 December 2011, 07:41:41 am »
I am beginning to wish I had  titled this  thread differently! Todays the day to sort timing out.
Will be taking  great care this time. I can`t bear driving my car any longer.
Slimted
Re: What a #osser!
« Reply #11 on: 04 December 2011, 07:56:17 pm »
All back together, but not starting........
