Date: 18-03-26  Time: 03:39 am
Author Topic: fazer 1000 ( 2001 ) gearbox fault - Please HELP  (Read 4510 times)
fazerderek
« on: 08 July 2013, 06:23:21 pm »
I have a 2001 fazer 1000 with 44k on the clock
It developed a clattering noise that stopped upon selecting a gear
I have removed complete clutch assembly back to the oil pump chain and found the gearbox input shaft has about 1/8th of a turn free play
I have been told this is the fault but without removing anymore i was hoping someone might know what is wrong to cause this fault
Can anyone help in my plight to fix my bike - Thanks in advance    .    Fazerderek.
fazerderek
Re: fazer 1000 ( 2001 ) gearbox fault - Please HELP
« Reply #1 on: 08 July 2013, 06:37:41 pm »
hope modifying my post helps
sadlonelygit
« Reply #2 on: 08 July 2013, 08:14:33 pm »
gen 1's can have problems with the selector forks due to cack handed 2-3 gearshifts on the back wheel.
also a possibility of a broken return spring in the selector area.
if the bike is in gear, you will have some backlash as the teeth mesh, check for up/down/left/right play in the shaft rather than rotational play.
did the noise go away with the clutch pulled in, or only on gear selection, that should tell you where the problem is!
but to save you the hassle i'll give you £100 for ii as a non runner ;)
fazerderek
« Reply #3 on: 08 July 2013, 08:52:29 pm »
Thanks for the info
Wow a £100 - that much
Thanks for the insulting offer but  NO
fazerderek
« Reply #4 on: 09 July 2013, 08:55:46 pm »
i was at the meeting at Birmingham classic bike museum with a friend on his thunderace
fazerderek
« Reply #5 on: 09 July 2013, 09:09:12 pm »
I have found a local guy who will strip and rebuild my gearbox to former glory so looking like i will be sorted in the near future at a minimum cost to my pocket
I have owned this bike for 6.5 years and its the first major engine issue ( not including ex-up valve problems )
andybesy
« Reply #6 on: 09 July 2013, 11:28:01 pm »
Let us know how you get on, and in particular what the problem turns out to be.
fazerderek
« Reply #7 on: 17 August 2013, 07:07:16 pm »
Gearbox fault fixed
1st gear pinion/bush and output shaft was shot
I still have rest of the box if anyone needs any spares ( on the cheap )
