Date: 28-03-26  Time: 16:59 pm
Author Topic: FZS600 - Exhaust  (Read 4591 times)
garyb
FZS600 - Exhaust
« on: 06 July 2013, 02:31:47 pm »
Folks my year 2000 boxeye came fitted with a lovely stainless 4-1 system and has a viper can with link pipe fitted too.
I am finding the viper can too loud for me (even with the baffle in) and would prefer a stock can for the quiet life
My question is will a standard can fit on the 4-1 pipe? and if yes, does anyone have a standard can for sale?
I have no idea what make the 4-1 system is.
Any help or suggestion appreciated.
Thanks Gary
Re: FZS600 - Exhaust
« Reply #1 on: 06 July 2013, 03:50:56 pm »
Hard to say for definite if the link pipe will fit, as some makes do differ in size, especially as you don't even know the make.
If you wait a couple of hours i'll measure the diameter of the one in my garage for you.
http://www.fazerspares.com/catalogue/131-1_fuel-and-exhaust.htm
garyb
« Reply #2 on: 06 July 2013, 04:02:11 pm »
That would be great - appreciate it.
I think I will take off the viper can and link pipe and measure the outside diameter of the 4-1 pipe too.
Cheers :)
lds1973
« Reply #3 on: 06 July 2013, 04:06:10 pm »
If its the same as standard can we strike up a swap deal for my standard?
Cheers
« Reply #4 on: 06 July 2013, 04:29:30 pm »
Standard end can has an approximate inner diameter of 50mm, but mine has an inner sleeve that makes it approximately 47mm.
Hope that helps.  8)
garyb
« Reply #5 on: 06 July 2013, 04:51:25 pm »
Hope that helps.  8)
Cheers mate - I just measured the O/D of my 4-1 pipe and as best as I can see it's about 45mm or so - I reckon its close enough to match up.
Cheers
Sure why not - sounds like a good option for us both  :)
« Reply #6 on: 06 July 2013, 05:15:41 pm »
You will need that inner sleeving then.
lds1973
« Reply #7 on: 06 July 2013, 08:51:22 pm »
Ill pull mine off soon (?) and just check the sizes and sleeving. Ill also send you a pic of mine cos it has a couple of places where my heel has took some paint off the link pipe.
The silencer itself is spotless.
« Reply #8 on: 07 July 2013, 08:42:37 am »
It's a bugger when that happens....
ChristoT
« Reply #9 on: 07 July 2013, 02:50:45 pm »
Your pipes look identical to mine, so should be fine. On the stock can, be careful with the heat paste & mesh infill - I buggered mine up before I got the new can, and needed a lot of exhaust cement to fix it!  :eek
lds1973
« Reply #10 on: 08 July 2013, 09:51:56 am »
20130707 130334
20130707 130334
20130707 130348
20130707 130348
20130707 130401
20130707 130401
Any tips on getting the foccer off would be gratefully appreciated.
Dead Eye
« Reply #11 on: 08 July 2013, 11:08:35 am »
Its two bolts and just pull it - its soo easy even a blind man could do it
lds1973
« Reply #12 on: 08 July 2013, 01:17:26 pm »
Its not pulling off. Its not twisting off. I have stainless headers on so I'm thinking they may be some very old exhaust sealant keeping it stuck fast.
I've tried tapping it off also but I don't want to damage the thing if its going to someone else.
Dead Eye
« Reply #13 on: 08 July 2013, 02:33:41 pm »
Huh... well that throws my analogy out the window
I've never come across a stock one that doesn't just pull off without much effort :( Not sure what to suggest as you appear to have tried everything I would have
« Reply #14 on: 08 July 2013, 02:50:01 pm »
Bit more brute force whilst twisting is needed, it will come off, it's only a pipe over a pipe!
garyb
« Reply #15 on: 08 July 2013, 04:40:24 pm »
Yeah - don't wreck that now you hear!
The viper came off mine no bother. There was a gasket on the link pipe where it joins the header so will leave that in if you can do the same for your one.
lds1973
« Reply #16 on: 08 July 2013, 06:59:47 pm »
I will keep trying. Ill have a go tomorrow after ive used the bike, maybe a bit of heat might help.
« Reply #17 on: 08 July 2013, 08:40:15 pm »
It will help you burn yourself  :lol
lds1973
« Reply #18 on: 09 July 2013, 05:54:24 pm »
20130709 175116
20130709 175116
Success. Ill pm you garyb.
garyb
« Reply #19 on: 09 July 2013, 06:07:31 pm »
Grand so  :)
