Date: 12-05-26  Time: 07:04 am
Author Topic: How the hell do you remove the Cambox Cover ???  (Read 2718 times)
YamFazMan
« on: 30 June 2013, 03:23:57 pm »
Hi
I'm about to check the valve clearances 24000 mile service, All the bolts removed, Cambox Cover loose  But How the hell do you remove it from the bike ???.
ATB YFM
Punkstig
Re: How the hell do you remove the Cambox Cover ???
« Reply #1 on: 30 June 2013, 04:52:18 pm »
Unless you're having problems with the bike running don't even bother checking them at 24000, both my fazer and thundercat were run past 120,000 without them being done!
His Dudeness
« Reply #2 on: 30 June 2013, 05:22:48 pm »
You might have to remove the bolt holding the thermostat in and wiggle it out of the way to get a bit more room
YamFazMan
« Reply #3 on: 30 June 2013, 06:00:29 pm »
Hi
Thanks for the reply's I tried the thermostat bolt "No joy" so I held the cover open with a small block of wood under each corner and checked the clearances like a gynaecologist  :)  All the clearances were in-spec  :D
Thanks again ATB YFM
His Dudeness
« Reply #4 on: 30 June 2013, 06:10:17 pm »
Well done. Didn't know gynaecologists used blocks of wood :lol
