Date: 01-04-26  Time: 11:22 am
Author Topic: NOT FRONT SPROCKET NUT AGAIN  (Read 3943 times)
jason1
« on: 27 June 2013, 05:34:53 pm »
Hi , KNOW THIS HAS BEEN COVERED, BUT TOOK COVER OFF TODAY TO GIVE A BLOODY GOOD CLEAN AND MEASURED FRONT SPROCKET NUT AND IS ONLY 9MM , IS IT RIGHT NEW UPGRADE IS 12MM? WAS LOOKING FOR THREAD ON HERE FOR BEST PLACE TO GET ONE ( MUST BE BLIND)CAN ANYONE POINT ME IN THE BEST DIRECTION ? HAS BEEN FINE FOR PAST FEW YEARS BUT RATHER CHANGE NOW . CHAIN AND COVER ARE ALL CLEAN AND RE-LUBED UP NOW ;-)
Thorn
Re: NOT FRONT SPROCKET NUT AGAIN
« Reply #1 on: 27 June 2013, 05:50:07 pm »
WHAT WAS THAT? I CANT HEEEAR YOU
Andy FZS
« Reply #2 on: 27 June 2013, 05:58:24 pm »
Yes moded nut 12mm available from you local dealer. Part number is on here somewhere if you you need it.
Andy
andybesy
« Reply #3 on: 27 June 2013, 06:05:42 pm »
Hi Jason,
I ordered it online here:
http://www.wemoto.com/bikes/yamaha/fzs_600_fazer_sp/02-03/
If you look for "Sprocket Front Retaining Nut Kit (OEM)" you'll see it's described as:
"This is the OEM Yamaha Nut and washer kit 90891-10124-00, the later up rated kit for earlier bikes with the troublesome thinner nut."
http://www.wemoto.com/bikes/yamaha/fzs_600_fazer_sp/02-03/picture/sprocket_front_retaining_nut_kit_oem/
I'm told you can probably get it for free from your dealer and save a tenner, but another option for you if more convenient and shows part number at least.
Andy
Punkstig
« Reply #4 on: 27 June 2013, 07:42:26 pm »
Just over £2 from a dealer with the tab washer included!
jason1
« Reply #5 on: 27 June 2013, 08:12:54 pm »
Thanks all , ordered  :D
Jc72
« Reply #6 on: 27 June 2013, 11:28:56 pm »
What's wrong with the front sprockets then, and  does it affect all years? Mines a 2003 fox eye
« Reply #7 on: 27 June 2013, 11:45:55 pm »
They either seize/weld themselves on, come loose or just disappear completely.
You need to upgrade the 9mm wide nut to a 12mm wide nut and washer kit, part number 90891-10124
Personally i would get it changed next time you renew your chain and sprockets just for peace of mind, or asap if you're the worrying type.
Dave48
« Reply #8 on: 28 June 2013, 09:39:26 am »
Its £2-44 exactly from my local Yamaha dealer-pick up. Very small price for peace of mind!
garyb
« Reply #9 on: 14 July 2013, 03:23:30 pm »
Just checked mine after reading this thread and it's not good news, the 9mm nut was loose and only being held on by the tab washer.
I tried to tighten it up again but it won't (i.e. it will thread along the shaft fine but it won't fully tighten up at the end)
Looks like the thread on the nut is worn and thankfully not the thread on the output shaft.
Asides from ordering the new bigger nut is there anything else I can do with this in the short term as a temporary fix?
Punkstig
« Reply #10 on: 14 July 2013, 03:40:16 pm »
Apart from not riding it, not really
« Reply #11 on: 14 July 2013, 03:45:11 pm »
It's too dangerous to start attempting any kind of short term fix, and the fact that you now know about it is more than enough to suggest getting it sorted properly.
If anything went badly wrong while you were riding it you wouldn't forgive yourself.
garyb
« Reply #12 on: 14 July 2013, 04:04:44 pm »
Thanks your right, I'll stick it in the shed until the new nut and tab arrive.
