Date: 02-05-26  Time: 15:10 pm
Author Topic: rear wheel bearings  (Read 6157 times)
justy1
rear wheel bearings
« on: 21 June 2013, 05:15:49 pm »
been told the rear wheel bearings need changing at some point.
any recommendations on what ones are best/most popular? bikes a T reg mk1.
many thanks
justy1000
otis
Re: rear wheel bearings
« Reply #1 on: 21 June 2013, 06:10:43 pm »
If you can find a bearing wholesaler in your area you will get better quality bearings and a hell of a lot cheaper.
I always use the 2 or 3 in my area every time and most are of the shelf. Any of the Jap makes are bang on
JZS 600
« Reply #2 on: 21 June 2013, 06:28:14 pm »
Fiver each on Wemoto or get the bearing code and go for SKF
stevierst
« Reply #3 on: 21 June 2013, 06:28:31 pm »
Yep, take the old bearing into a wholesales bearing place, and get one from the experts!
JZS 600
« Reply #4 on: 21 June 2013, 06:33:23 pm »
His Dudeness
« Reply #5 on: 22 June 2013, 09:32:27 am »
The original ones in the front are koyo so I presume the rear are the same but skf, fag are top quality too
« Reply #6 on: 22 June 2013, 09:50:19 am »
http://www.timken.co.uk/en-US/about/NewsRoom/Stories/Pages/LaunchesAwarenessCampaignAgainstProductCounterfeiting.aspx
Oh yes, there is a World Bearing Association
More bearings, Norma?  :lol
These very important people help the world go round  :rollin :rollin :rollin
Biggy461
« Reply #7 on: 22 June 2013, 10:12:57 am »
I got mine from WeMoto for about £35 I think for all of them front, rear and sproket and seals.
Delivered quick as well - no issues yet.
stevierst
« Reply #8 on: 22 June 2013, 02:28:24 pm »
Darsi, get your coat!!!   :fish   :rollin :rollin
JZS 600
« Reply #9 on: 22 June 2013, 05:18:17 pm »
I'll see you around (boom boom!)
justy1
« Reply #10 on: 26 June 2013, 11:36:35 am »
cheers guys.
always buy my bearings from the local bearing dealer. just wanted to know what the best/most commonly used bearings were as this is the 1st time ive had to change um.
anyone know the code as i cant really take um out as the bikes my only mode of transport.  :\
thanks again.
justy1000
« Reply #11 on: 26 June 2013, 11:52:09 am »
 had a full set once.....lost a few now though  :lol
gassitt
« Reply #12 on: 26 June 2013, 12:05:53 pm »
Rear wheel   6204 2RS      Sprocket carrier   6206 2RS
And the best ones are the ones I get free from the stores at work  ;)
« Reply #13 on: 26 June 2013, 06:44:14 pm »
The Fzs 600 bearings are:
Front  Wheel 6203-2RS CN or C3
Rear Wheel 6204 - 2RS CN or C3
Sprocket Carrier 6206 - 2RS CN or C3
RS is for rubber seals an CN is Clearance Normal and C3 is Clearnce Code 3
The clearance is measured  between the balls and the rings and you have C1, C2, CN, C3, C4, C5. There is aslo a CM clearance which is in and around the same clearance as CN and often used to reduce noise.
C1 has the smallest clearance and C5 the largest.
The possible heat (disk transfer) and vibrations (road surfaces and out of balance) the wheels would really necessitate CN or C3 specification, C3 being the most common aftermarket type
Since the bearing is a vital part in the bike, for your own safety stick with known brands :)
JZS 600
« Reply #14 on: 27 June 2013, 12:43:12 pm »
Check out the World Bearing Assocation for confirmation!
justy1
« Reply #15 on: 27 June 2013, 06:43:30 pm »
cheers....
ive got 6204.EEC3 (J30)............. ope theyre the right ones? :\
justy1000
