Date: 12-05-26  Time: 04:46 am
Author Topic: Oil filter removal  (Read 5656 times)
Fraser
Oil filter removal
« on: 19 June 2013, 06:05:32 pm »
Seems pretty obvious really ! I recently got a 98 FZS600, ordered my service kit, got bike on stand in garage, so far so good, its got after market stainless down pipes, not enough room to get filter out !! do I really have to remove downpipes to get filter out ?  I hope not cuz the manifold studs are rustier than a rusty thing , any advice would be very welcome, thanks, Fraser
kebab19
Re: Oil filter removal
« Reply #1 on: 19 June 2013, 06:08:57 pm »
Get one of these & attach to a ratchet to save yourself stabbing it repeatedly with a screwdriver, useful as a long-term labour saver
Item number:
150785708962
Fraser
« Reply #2 on: 19 June 2013, 06:14:05 pm »
I've already got one of those, getting the filter undone is not the problem, its how to get the filter out through a gap that is too small LOL
Dcock
« Reply #3 on: 19 June 2013, 07:06:01 pm »
hmm, with normal downpipes you definitely don't have to remove them to remove the oil filter... so sounds like you might have to drop the pipes due to poor design! Is the new filter the same size?
bandit
« Reply #4 on: 19 June 2013, 07:18:40 pm »
I have Motad downpipes & after unscrewing the filter if you rotate the filter & follow the curve of the pipes down you can get it out of the left hand side at the bottom if you've got the correct size filter. :)
« Reply #5 on: 20 June 2013, 12:22:04 am »
Post a picture
Stooby2
« Reply #6 on: 20 June 2013, 08:31:13 am »
There are some aftermarket pipes that don't allow the oil filter to come off - piss poor design. My mate at work bought a Fazer with some stainless downpipes and found he had to remove them to get the oil filter off. He's changed the pipes now.
Fraser
« Reply #7 on: 20 June 2013, 08:46:17 am »
Thanks for all the replys, it looks like a poor design, I'm going to try to undo the front engine mount cradle to see if that will give me a bit more room, I've got the correct (small) filter, fingers crossed ,
richfzs
« Reply #8 on: 20 June 2013, 09:05:58 am »
Or undo the exhaust can bolt, and (carefully!) allow the exhaust system to flex down. Might give the room you need.
Thorn
« Reply #9 on: 20 June 2013, 02:25:56 pm »
Uh oh, do sandybikespares downpipes suffer from this?
iJoshL
« Reply #10 on: 21 June 2013, 03:39:08 pm »
Must be poorly build downpipes, i've got aftermarket delvick exhaust and downpipes attached to my Fazer and removing the Oil Filter is not a problem in the slightest. close but not a problem with both hands.
Dead Eye
« Reply #11 on: 30 June 2013, 07:07:58 pm »
I have sandybikespares pipes on and haven't had any issue in removing / replacing the oil filter with them :)
« Reply #12 on: 30 June 2013, 07:43:05 pm »
Yeah i don't have any trouble at all with space when fitting/removing my filters?
Thorn
« Reply #13 on: 30 June 2013, 07:45:50 pm »
Good to know, I was getting a bit paranoid there! Personally in the ops situation, I would heat the pipes up then whack them with a hammer until they are bent out of the way enough to access the filter  :evil
