Date: 25-05-26  Time: 06:33 am
Author Topic: upgrading rear light bulbs  (Read 4012 times)
solorider
« on: 17 June 2013, 10:09:26 pm »
I bought a couple of led stop tail bulbs to replace the crap normal bulbs that I have fitted at the moment, I have to open up the hole slightly for them to fit, the bulbs I got give out a white light and I will take a comparison picture to see how much difference there is
seangee
Re: upgrading rear light bulbs
« Reply #1 on: 19 June 2013, 12:35:36 pm »
You shouldn't have to open out the hole.
This pic is of two LEDs. The first was a budget one that claimed to be the brightest on the planet and TBH I struggled to see the difference between that and stock.
The second cost a bit more but well worth the money. (Sorry I don't remember where or what)
solorider
« Reply #2 on: 19 June 2013, 02:47:30 pm »
I used the slightly larger led bulb which has all the led's on the end, then I remembered they only put out light in one direction so would not illuminate the number plate, and what didn't help was the bulbs didn't get any brighter when you applied the brake light!!! so they are going back, when I had my firestorm the red coloured bulbs worked as they should. I am thinking of these bulbs on eBay  http://www.ebay.co.uk/itm/121128611562?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2648 which hopefully are better than this type http://www.ebay.co.uk/itm/130451897163?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 which were crap
dickturpin
« Reply #3 on: 19 June 2013, 06:34:33 pm »
I tried some of the second type for the cage and also found them too big!
Have you seen these?
http://www.ebay.co.uk/itm/130913736602?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
solorider
« Reply #4 on: 19 June 2013, 08:31:38 pm »
how much too big is the bulb?
dickturpin
« Reply #5 on: 19 June 2013, 09:02:54 pm »
The link is the bulbs I am thinking of getting.
The ones I got for the cage were about 2mm diameter too large to fit into the lens space.
I did try grinding the edge off but they broke before I got enough of the plastic removed.
solorider
« Reply #6 on: 20 June 2013, 02:38:15 pm »
that bulb will be no good for your brake light as you need a stop/tail bulb
dickturpin
« Reply #7 on: 20 June 2013, 07:36:46 pm »
I tried these but I didn't think the brake light made sufficient difference to the tail light so I took them out
http://www.ebay.co.uk/itm/2X-Car-1157-BAY15D-P21-5W-380-68-SMD-LED-White-Stop-Tail-Brake-Light-Lamp-Bulb-/400499537642?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d3fa1f6ea
Well spotted on the last link...i'm doing something similar on the car and got confused!
D
solorider
« Reply #8 on: 21 June 2013, 03:09:46 pm »
I have for the moment fitted some bike specific halfords quick illuminate rear stop ta bulbs,they are supposed to light up faster and brighter than normal bulbs
