Date: 07-05-26  Time: 07:55 am
Author Topic: Near side fairing cracked round indicator  (Read 1910 times)
m4tth3w
« on: 17 June 2013, 02:23:07 pm »
The fairing around my indicator on the near side of front fairing is crap and looks horrible is there any general well-known fixes for this issue.  I think a round decal to stick around it would look good any suggestions.  Thank you
Arfa
Re: Near side fairing cracked round indicator
« Reply #1 on: 17 June 2013, 03:00:52 pm »
Done same to mine, after a drop pushed indicator stalk in, cracking the fairing from indicator hold down to bottom edge. Yours must be worse, as the crack on mine is hardly noticeable.
Either way, I was told a spot of glue and bit of plastic welding on the inside would sort it out. Just a case of finding someone local with these skills.
Lazarus
« Reply #2 on: 17 June 2013, 03:10:35 pm »
where u based matthew?
bwizz
« Reply #3 on: 17 June 2013, 03:18:24 pm »
Mine was broke of completely. I stuck it together with araldite, then i cut a piece of metal body repair mesh and fibre glassed it in from behind
finally On the outside I ground around the break with a dremmel and filled it in with body filler I masked of the area from the rest and finished of with aerosol paint. can't tell it was broke now!
m4tth3w
« Reply #4 on: 17 June 2013, 08:27:07 pm »
As u can see mine is on the shitier end of the shit scale
I'm in barnsley
Lazarus
« Reply #5 on: 17 June 2013, 10:36:56 pm »
ok - guy local in ayrshire can fix that - bit of a trek for you though !!! :|
