Date: 08-05-26  Time: 09:42 am
Author Topic: DOT4 or DOT5  (Read 2624 times)
mobile mouse
DOT4 or DOT5
« on: 02 June 2013, 12:18:07 am »
Hi,
After fitting braided hoses to the front.
Can you use DOT5 brake fluid or is this over the top or a good upgrade.
mickvp
  • Global Moderator
Re: DOT4 or DOT5
« Reply #1 on: 02 June 2013, 12:25:30 am »
unless you have flushed out ALL the old brake fluid, I wouldnt put DOT5 brake fluid in...
DOT5 brake fluid is silicone based, as opposed to DOT4 being Glycol based: the two are not interchangeable/cannot mix.
Also, DOT5 is not rated for any kind of Track use due to its lower boiling point (in comparison with DOT4), so if you plan on doing a lot of heavy braking or track work, I would stick with DOT4  :lol
Unless of course you mean DOT5.1, which is a different beast entirely and probably is a worthwhile upgrade (DOT 5.1 is also glycol based, and so can mix somewhat with DOT4 just to add to the DOT4/5 confusion!)
You can find a pretty good explanation of the various DOT brake fluids from Opie Oils
HTH
Mick
JoeRock
Re: DOT4 or DOT5
« Reply #2 on: 02 June 2013, 02:26:44 am »
Personally I'd still stick to Dot 4. Unless you ride a lot on track, braking heavily (and I mean SERIOUSLY heavily), you won't need the higher boiling point of the 5.1. You also have to bleed 5.1 more as it absorbs water quicker. You'd be much better off just getting a good 4 instead IMO
Dead Eye
Re: DOT4 or DOT5
« Reply #3 on: 02 June 2013, 06:17:18 am »
The Opie Oils article is good, I've read it before :)
If you want higher performance then there is a high spec / race DOT 4 variant which has a higher boiling point
mobile mouse
Re: DOT4 or DOT5
« Reply #4 on: 02 June 2013, 09:55:41 pm »
Filled with DOT 4.
Did not look to get a hard brake lever after filling and bled both calipers.
So stopped parked bike in garage and tied brake lever back.
Two hrs later went back and what a difference I now have a good firm brake lever.
Thanks for the advice I already had the DOT 4 didn't know the difference with the DOT5 and DOT 5.1 until reading the Opei Oils article.
Maybe next time I may consider DOT5.1.
69oldskool
Re: DOT4 or DOT5
« Reply #5 on: 06 June 2013, 08:03:49 pm »
..... You also have to bleed 5.1 more as it absorbs water quicker. You'd be much better off just getting a good 4 instead IMO
That's worth knowing.
Cheers. back to dot 4 next time methinks.
