Date: 19-01-26  Time: 09:40 am
Author Topic: Dent puller  (Read 4025 times)
simonm
Dent puller
« on: 31 May 2013, 12:15:37 pm »
As I have widely advertised in my shy way I have a substantial handlebar shaped ding in my fuel tank.  It has definite creases and I don't think a suction puller would cut the mustard.
To compound the issue the cost of the tank vs a body shop makes it financially hard to justify the cost.
So two questions:
- is the fazer tank twin skinned?
- should I just leave it dented or should I have a go with one of these?  http://www.ebay.co.uk/itm/SPRING-SALE-POWER-TEC-92376-PAINTLESS-DENT-REMOVAL-SLIDE-HAMMER-9-GLUE-PADS-/181145195228
I know worst case scenario is a wrecked tank and I should empty it of fuel first but any other advice ?
Re: Dent puller
« Reply #1 on: 31 May 2013, 12:19:37 pm »
Unless its causing a problem, I would leave the dent alone until funds allowed for a new tank or a professional repair job.
Re: Dent puller
« Reply #2 on: 31 May 2013, 12:24:23 pm »
pretty sure the tank is single skined......i`ll be surprised if that slide hammer will pull the dents out ,i dont think it will be man enough....the ones i have used in the past have a self tapper on the end but does mean drilling a hole in the tank and welding up when finished but will pull the dent out........there are other more expensive types which fuse a rivit to the surface and then use the slide hammer attached to that and simply cut off when finished.....expensive and probs not worth it for the one job  ;)
dickturpin
Re: Dent puller
« Reply #3 on: 31 May 2013, 01:38:11 pm »
have you thought of one of the 'just dents' type repairs for cars? I had a car door dented in a car park and that sorted it....99% better. £30cash!
Re: Dent puller
« Reply #4 on: 31 May 2013, 02:20:34 pm »
When I needed a new tank I picked one up second hand for £45 delivered so not exactly expensive. The breaker yard I went to wanted £90 at the time...
I'd just leave it be for now and get a second hand one. Don't worry about colour too much, can always spray it, have it vinyl wrapped or cover it with a tank bag
Re: Dent puller
« Reply #5 on: 31 May 2013, 02:32:13 pm »
If the damage is all below the original surface level then car body filler and some touch-up paint should make it almost unnoticeable.
alan sherman
Re: Dent puller
« Reply #6 on: 31 May 2013, 05:19:01 pm »
I had a football sized dent in the top of my tank.  A suction cup on a phone holder for the car windscreen pulled it out!
The tank must be single skinned.  Infact you can see on the weld line the two pieces of material.
chris.biker
Re: Dent puller
« Reply #7 on: 31 May 2013, 11:10:22 pm »
A photo of the dent in the tank would be interesting to see.
Re: Dent puller
« Reply #8 on: 01 June 2013, 12:40:28 am »
There's a few images of the damage in the 600 forum; found this thread by our dear simonm highlighting the unfortunate "dent" http://foc-u.co.uk/index.php/topic,7196.msg68664.html#msg68664
Re: Dent puller
« Reply #9 on: 01 June 2013, 07:00:00 am »
reading back through this thread , it looks like DICKTURPINS idea is the best.......think i`ve seen one near me called DENT BUSTERS, as you have a crease they wont be able to remove it completely but a skim of filler will sort that out  ;)
chaparral02
Re: Dent puller
« Reply #10 on: 01 June 2013, 08:21:49 am »
Maybe you be better off making an offer on something like this one
http://www.ebay.co.uk/itm/yamaha-fazer-600-fuel-tank-from-a-1999-model-/200922799185?pt=UK_Motorcycle_Parts_13&hash=item2ec7ee9c51
(PS: don't know if it from the same model year as your bike)
simonm
Re: Dent puller
« Reply #11 on: 01 June 2013, 11:25:36 am »
Thanks for pointing out a pic of it.  Appreciated. :)
