Date: 09-05-26  Time: 19:13 pm
Author Topic: brake seal kits & pads question  (Read 2767 times)
Enceladus
« on: 31 May 2013, 11:16:11 am »
when i change my brake lines over to braided ones i might as well give the brakes a clean and new seals as i don't know when they were last done.
there is still quite a bit of meat on the pads, but as the bike has only done 8.5k miles (on a 2002 plate!) i think they might be the originals and ought to be replaced.
are any seal kits better than others or are they all pretty much the same ?
what about brake pads ?
any better than others ?
thanks all :)
bandit
Re: brake seal kits & pads question
« Reply #1 on: 31 May 2013, 12:51:49 pm »
If the brakes are working fine & not sticking I personally would just change the brake lines no point in putting new pads & seals in if their seals not leaking. :)
« Reply #2 on: 31 May 2013, 01:08:37 pm »
Agreed, if it ain't broke, don't fix it!
Skippernick
« Reply #3 on: 31 May 2013, 01:22:36 pm »
 :agree  and thats my plan when the time comes, might pump the pistons out a bit and clean the end of them though.
bandit
« Reply #4 on: 31 May 2013, 01:54:59 pm »
Thats what I suggest same as Skippernick,pump pistons out a little clean with some brake cleaner & put a smear of red rubber grease around the dust seals where they meet the piston. ;)
« Reply #5 on: 31 May 2013, 04:30:32 pm »
Give 'em a good scrub with a toothbrush and brake cleaner, and remove any rust spots with strips of wet 'n' dry, then red rubber grease the exposed parts of the pistons before pushing them back in.
I do this at least 3 times a year and it keeps them in good working order.  :D
