Date: 21-03-26  Time: 23:33 pm
Author Topic: Tutoro Auto Chain Oiler  (Read 5288 times)
hightower
« on: 30 May 2013, 03:36:58 pm »
Took delivery of my Tutoro Auto Oiler today, and impressed with the quality of the kit. I've fitted it to the front strut of the rear left foot peg - there wasn't many places to strap it to the Fazer I found.
Need to give it a run out and fiddle with the flow until it's right, but I plan on making a quick video about my fitting position (and tube routing) once I'm happy with flow.
Just got me thinking though, where have you fitted your Tutoro?
Punkstig
Re: Tutoro Auto Chain Oiler
« Reply #1 on: 30 May 2013, 07:52:38 pm »
I use one of the bolts on the rear hugger/chain guard for the scottoiler, don't know about space required for yours
stevierst
« Reply #2 on: 30 May 2013, 09:31:53 pm »
I'll look forward to your video Hightower, the Tutoro is probably the only oiler i haven't used, and always been a bit curious about.  ;)
tweetytek
« Reply #3 on: 25 August 2014, 11:02:14 pm »
Was thinking of starting a new thread on this old topic - but I felt this question was on topic and valid - Stevlerst - did you get the video done or have some stills to show us , I'm thinking of buying one
stinch182
« Reply #4 on: 25 August 2014, 11:09:00 pm »
I have one . I picked it up from Nick directly top bloke very helpful . I hid mine under the seat .
tweetytek
« Reply #5 on: 25 August 2014, 11:22:45 pm »
any images of the fit mate? I was wondering whether to go for basic or standard (latter has the bracket - do I need one, hence request for images) - the deluxe is an overkill for me.
also, do you have to turn it off when not riding as the inertia system should not be operating when still and thus not dripping oil??
stinch182
« Reply #6 on: 26 August 2014, 12:45:15 am »
I got the deluxe kit . The bracket is handy for fitting . I'll find the pics I took for you . Unless the bike is moving the oil won't feed through as the movement up and down opens the valve . Very clever and simple design .
tweetytek
« Reply #7 on: 26 August 2014, 12:55:43 am »
gr8. thanks. I'll go for one once I see your fit images. thanks
Marsiepan
« Reply #8 on: 01 March 2015, 09:32:20 am »
I've just bought a deluxe kit but can't see where I can fit this. Could you let me know whereabouts you mounted it. Thanks
Deefer666
« Reply #9 on: 01 March 2015, 10:55:38 am »
I have fitted one of these for a customer, I tucked it behind his wing rack. They are a good piece of kit and I would say definatley better than the Scottoiler system. Although as with the Scottoiler systems I fitted it so it fed the front sprocket as I really dislike oil lines trailing along the swing arm.
Paulfzs
« Reply #10 on: 01 March 2015, 03:33:48 pm »
Am i being a bit simple with auto chain oilers....
you adjust it for the flow rate you want then leave it.. but what happens when you stop riding and leave it parked up, surely it will just drip oil onto the chain overnight
limax2
« Reply #11 on: 01 March 2015, 04:26:44 pm »
It's never being simple to ask a question if you don't know something.
When you park up the flow of oil automatically stops. I don't know how but in the blurb it says it utilizes the inertia and normal motion changes of the bike when in use. More info here
http://www.tutorochainoiler.com/index.php/store-mobile/oiler-auto-standard-detail
Paulfzs
« Reply #12 on: 01 March 2015, 04:43:05 pm »
Ahh thanks, that kind of makes sense i suppose.
Fazafou
« Reply #13 on: 01 March 2015, 05:08:14 pm »
There's a large metal disc in there with a needle that blocks off the flow when stationary. When the bike hits bumps etc in normal riding, the movement makes the weight lift and allow flow.
I had one and ended up chucking it, flow eventually stopped over time.
I now use a PDOiler which is electrically pumped. No fiddling around with gravity feed and it's a controlled output regardless of temperature etc :)
