Date: 09-05-26  Time: 09:26 am
Author Topic: Disappointed with FZS 600  (Read 10139 times)
trundle
« on: 27 May 2013, 12:43:08 pm »
HI all
Had my Fazer for a couple of weeks now and I must say I'm really disapointed with it. The vibrations through the right handlbar, and to a lesser extent, the right footpeg are bloody awful. The screen is useless. Why bother putting one on it when it does bugger all apart from direct the wind and flies right into your face? I bought a MRA Vario screen and what a bloody joke - £109 wasted. Its no better than the original and the stupid spoiler thing (gimmick) makes no difference whatever position its in. Anyway rant over. Ayone want to buy a 2002 Fazer 600?
Trundle
Re: Disappointed with FZS 600
« Reply #1 on: 27 May 2013, 12:47:56 pm »
Maybe a carb balance could help with the unwanted vibes?
Can't say i've heard anyone complain about feeling in the right footpeg before to be honest?
Chris
« Reply #2 on: 27 May 2013, 01:02:16 pm »
Also might be worth checking wheel allignment and bearings to see if that stops the vibes, fazers aren't generally a very vibey bike.
As for the screen, a powerbronze double bubble is fine on mine.
Chris
Dave48
« Reply #3 on: 27 May 2013, 07:01:00 pm »
As Chris & darrsi suggest why not check the bike over-could be as they say carbs out of balance, wheel alignment, bearings or engine mount bushes. Also have a look at your chain & sprockets. The Fazers not perfect but should be a smooth ride if everything ok.
stevierst
« Reply #4 on: 27 May 2013, 07:19:39 pm »
I've had three fazer 600's and covered a lot of miles on them. Not felt any vibes on them, they're normally a smooth bike!
There's something not right with yours!
Sent from my AT300 using Tapatalk 2
john 087
« Reply #5 on: 27 May 2013, 07:24:20 pm »
I have a 98 fazer with 58000 miles never noticed any vibes.
limax2
« Reply #6 on: 27 May 2013, 07:51:45 pm »
Trundle also has a Harley  8) ,  so surely saying I'm disapointed with a Fazer has got to be a wind up  :eek .
To be a bit more helpfull, some FZS600's have a slight vibration patch between about 5,800 and 6,200 r.p.m. but usually only felt at the handlebars and not enough to spoil the ride. I agree the standard screen is pretty useless, but find the double bubble on my Mk1 Fazer 600 (rectangular headlights model) works good for me.
Hope you get it all sorted and come to love it.
trundle
« Reply #7 on: 27 May 2013, 08:22:12 pm »
Hi all
Yes Limax2 I do have a Harley and the 'engine' vibrates like hell but there are no vibes felt at bars or pegs or anywhere else. The engine is designed to move fore and aft on rubber mounts. Anyways it seems like I have a problem. Carb balance will be my first task methinks.
Trundle
Kentish
« Reply #8 on: 27 May 2013, 08:30:21 pm »
where r u based trundle? oh and how much do you want for it?
hightower
« Reply #9 on: 27 May 2013, 09:04:51 pm »
I've noticed on mine there can be a little (not much) vibe through the pegs at around 5000 rpm, but I just tend to knock it up a gear if I'm cruising to get it out of that range.
simonm
« Reply #10 on: 27 May 2013, 10:18:52 pm »
HI all
Trundle
I'm not exactly sure that the popularity of the bike, a forum dedicated to it and the reviews back up your assertion.  However I would be whole heartily inclined to believe the other foc'cers.  There is summat up with yours. Could be a multitude of things including (possibly) wheel balancing, rear wheel chain alignment off.
The screens on a lot of bikes are useless, they're even worse on naked/street fighters  :lol .  You're going to get flies in your face (preferably closed visor) whatever happens so best just deal with it.[/size][/font]
Please do some investigation on the bike before writing it off, they're stunning little bits of kit.
Simon
« Reply #11 on: 27 May 2013, 10:31:22 pm »
It won't be chain, sprocket, wheel alignment, etc,  if there's vibration in the right foot peg, he'd be immediately referring to the left peg, and it would be more than obvious.
I've just read on another forum about someone with the same problem, right foot peg and right handlebar vibration, and it turned out to be a broken engine mount bolt, on the right side!
Maybe worth a check to eliminate it?
simonm
« Reply #12 on: 27 May 2013, 11:43:27 pm »
 :oops   Time for me to  :tape  then  :lol
« Reply #13 on: 28 May 2013, 05:45:41 am »
I've had all the above problems and they simply have no effect on the right side of the bike.
I was out on the bike after reading this post yesterday and i had zero vibration or ill feeling from the right foot peg at all, so something is very amiss with trundle's bike for him to get that feeling, especially when it's mainly on the right side which is very unusual?
Dead Eye
« Reply #14 on: 28 May 2013, 10:26:24 am »
Ahah! This may explain my bike then... since I replaced the front sprocket, the vibrations from the left have gone, but I'm now noticing vibrations on the right, mostly through the right footpeg :P Since I had the engine out, its probably a good idea to check the mounts :P
Paul
« Reply #15 on: 28 May 2013, 03:09:55 pm »
I had a problem a bit like this when I got mine new in 2001 but mainly with vibration in the throttle hand.
I felt like I was always pushing myself back on the seat (seat slopes towards the tank).
I ended up having the seat re-shaped in 2003 (seat now rises up as it meets the tank) and the problem immediately disappeared.
The bikes now done 69,000 miles.
His Dudeness
« Reply #16 on: 28 May 2013, 09:59:14 pm »
It could be the exhaust vibrating. They seem to resonate at around 5-6000rpm and you'd probably feel it more at your right foot.
Dead Eye
« Reply #17 on: 29 May 2013, 12:35:26 am »
For me it happens all the way through the rev range. Pretty sure its engine speed and not road speed affecting it which to me is good as I have a spare engine :P
Slaninar
« Reply #18 on: 29 May 2013, 11:08:47 am »
HI all
Trundle
Try riding without the screen, you will notice difference. The screen helps to keep the wind off your chest. Without visor I always got too cold when riding, or, if dressed properly, too hot when stopped/going slow. Plus, at higher speeds, when you tuck down, visor is ultrahepful. If, however, you want a touring bike, not a sports-touring one, go for a nice big enduro with screen as big as you can find. It does keep bugs away better.
Vibes can be due to bad carbs synchronization - it's an inline four engine, should be as buzz free as possible. I did try riding single cylinder for a while and enjoy the difference. Just make sure it is set up right (carbs, and all the bolts in place).  :)
trundle
« Reply #19 on: 29 May 2013, 08:53:59 pm »
Well bugger me- I hadn't thought about the exhaust causing the vibes (His Dudeness). My bike has an aftermarket Arrow exhaust. Perhaps that's causing the vibes right bar and right footpeg doh. Will check that out as well as sync the carbs cheers.
Trundle
ltcorwin
« Reply #20 on: 01 June 2013, 03:20:49 pm »
Hmm, this might explain the vibration I've been feeling when I've been riding my bike more "positively" around the A4174 ring road recently.
Right foot only, at about those revs, mainly at the heel peg, not nearly ata ll on the rear brake, which I'd expect if it was engine noise.
Thanks
LTC
bwizz
« Reply #21 on: 01 June 2013, 09:38:06 pm »
I've got mra vario screens on both my gen 1 thou and foxeye 600.
I find them very effective, more so on the 600, I reverted to standard recently on the thou , thinking to sell the vario and put some money back in the bank. but I found I was getting a battering at 80mph that I had forgot about. So I've decided to keep it .
my 600 is smooth throughout the rev range , as others have said something amiss if there is any vibes in a fazer
