Date: 22-04-26  Time: 15:09 pm
Author Topic: EXUP cable issue  (Read 2137 times)
Camshaft
EXUP cable issue
« on: 18 May 2013, 09:41:10 am »
Hi,
Serviced the EXUP Valve today, snapped some bolts and tapped new threads to M8. So far so good.
When reinstalling the components to the exhaust and starting the bike the 7K PRM fault showed on the Tacho. I unbolted the bracket that holds the cables in place and turned the ignition key to ON and the cables retracted very tightly and won't pull back out and now cannot fit them with the bracket back onto the Valve shaft.
Before I lift the tank to access the Servo Motor can anyone help me out with some ideas what might be going on.
cheers
kylron
Re: EXUP cable issue
« Reply #1 on: 18 May 2013, 10:26:22 am »
There are cable adjusters under the right hand side of the petrol tank you should be able to adjust them to get enough slack to fit them back on to the valve.
Kosmic Kartman
« Reply #2 on: 18 May 2013, 12:25:26 pm »
Sounds like the cables, one or both, have snagged up by the servo.
bigsteve
« Reply #3 on: 18 May 2013, 03:03:06 pm »
 Hi just a thought you havent put pully and cables on wrong way around like i did  :eek    :rolleyes   :'(
Camshaft
« Reply #4 on: 19 May 2013, 04:08:16 am »
Ok, thanks guys fixed it now.
I had the valve at the wrong rotation before sliding the  cable pulley on  :eek
