Date: 07-05-26  Time: 03:14 am
Author Topic: led rear brake light  (Read 2595 times)
yamy
« on: 13 May 2013, 05:16:02 pm »
Hi all just got a set of led bulbs for brake lights but they seem dull
compared to the normal one's any ideas as to why and how to fix it
Re: led rear brake light
« Reply #1 on: 13 May 2013, 08:08:50 pm »
Hard to say. Do you have a link to the type you bought?
yamy
« Reply #2 on: 13 May 2013, 08:28:49 pm »
hi same fitting as a normal bulb but led . Off ebay £5
ade the blade
« Reply #3 on: 13 May 2013, 09:10:29 pm »
evening mate......if they are the SMD type then they are a total waste of money. utter shite ! put your old ones back in ........and breathe, everyone i speak to about them aint got any positive comments to give. type SMD bulbs into arsetube and listen to the reactions. sorry ! :'(
yamy
« Reply #4 on: 14 May 2013, 11:55:54 am »
cheers lads only a 5 so not too bad
Jamieg285
« Reply #5 on: 14 May 2013, 12:32:22 pm »
I've found LED bulbs to be a bit of a minefield.
There's all sorts of designs, types of LEDs, numbers of LEDs, etc. and they keep bringing out more.
It's not helped by the fact that most of them are coming from China where the quality is unknown until you get them.  They range from non-starter through to pretty good, but you can't tell which from an online advert. >:
Also, take a look at the design of the light you are using (not looked at my rear light yet, so I don't know).  Are they designed so that the light is direct from the bulb, or is the light reflected from the back of the housing?  Bear this in mind and look for LEDs that are pointing in the right direction.  If it is a reflector type, there's no point going for a bulb where they all point backwards.
The only advice that I can offer is try different ones.  Eventually you will find one that you are happy with (and lasts more than a couple of weeks)  I can't tell you how many you will need to try before you get there and how much will be spent doing it.
[size=78%] [/size]
yamy
« Reply #6 on: 14 May 2013, 09:18:00 pm »
Cheers all i think I'll go for a all in one rear light ,  it's £80
though
