Date: 22-04-26  Time: 05:58 am
Author Topic: Leak.... but what is it?  (Read 6620 times)
babemagnet
« on: 13 May 2013, 10:22:55 am »
My gen 1 fazer 1000 has started oozing brown gunk from small hole in left hand engine casing. Have owned various fazer 1ooos over last 10 years and this has never happened before. Any ideas?.....will try to attach photo
Re: Leak.... but what is it?
« Reply #1 on: 13 May 2013, 11:32:44 am »
Looks like engine oil coming from the spark plug well drainage hole so a damaged cam cover gasket would likely be the cause.
snapper
« Reply #2 on: 13 May 2013, 12:54:48 pm »
might be a loose plug ? #
 if your lucky  :'(
ghostbiker
« Reply #3 on: 13 May 2013, 02:05:58 pm »
Deff looks like oil in the picture, with out better info and pic etc I would say a seal or gasket is leaking in to the plug reses.
Tmation
« Reply #4 on: 13 May 2013, 02:46:03 pm »
When you have fixed the leak change the oil it looks dirty  :lol
slimwilly
« Reply #5 on: 13 May 2013, 05:09:44 pm »
Looks like it only leaked when stood still,,,,why???
ghostbiker
« Reply #6 on: 13 May 2013, 05:23:21 pm »
Parked on side stand? Leaning on that side let the pooled oil seep out maybe
chaparral02
« Reply #7 on: 13 May 2013, 06:12:33 pm »
Would it be possible that water from washing or rain has got into the area where the spark plug goes that the sparkplug cap normally seals and it just a some dirty rusty oily water coming out of the drain hole..
babemagnet
« Reply #8 on: 13 May 2013, 06:52:41 pm »
Bike has been sitting in shed since last july. has not got wet. Oil has just been changed and is a nice red colour still. After what has been said above I am also perplexed as to why it only seems to drain out when on side stand and not when in motion. I am now worried as am due to tour Spain at end of june and am now questioning whether it will do about 5000 miles. Should I fix before I go or will it last the holiday?
Tmation
« Reply #9 on: 13 May 2013, 07:42:38 pm »
Seriously, I think the above is bang on the money. Lift the tank, pull the plug leads and have a good look with a torch or as snapper says it might be a loose plug because that is not clean oil coming out of that hole.
Unless you are seriously unlucky I think you will find it is a quick fix.
Good luck
« Reply #10 on: 13 May 2013, 07:58:39 pm »
You should at least investigate it before going on a 5000 mile trip!
If it is just a bit of seepage past the cam cover gasket you'll probably have no problem beyond a slightly messy looking engine and the need to top up the oil occasionally, but it's not impossible that the cause is something critical. There's no point in having a ruined holiday for want of getting your spanners out or taking it to a mechanic if you're not confident of tackling the job yourself.
eddie
« Reply #11 on: 13 May 2013, 09:27:37 pm »
Or it could be rusty water  from the  metal coolant pipe that goes into the top of the head I have noticed mine has surface corrosion.. I would check the the hose  connection onto it
slimwilly
« Reply #12 on: 14 May 2013, 06:59:04 am »
Get it clean and give it some gas, go for a good ride and see what happens, hope you come back safe
babemagnet
« Reply #13 on: 16 May 2013, 06:12:30 pm »
Thanks foe all thwe above............turns out it was just shitty water sitting in top of engine because drain hole was blocked. As bike was on main stand and not being used this water just got shitty as it wasn't being boiled off with use. When put on side stand for first time after sitting it slowly oozed out. Took it to garage who blew all the crap out with an airline. Checked the plug recesses and no oil leaks...........Big Phew..... No leaks and no cost......Spain here I come.......one again thanks for all suggestions.
tomlinscote
« Reply #14 on: 16 May 2013, 07:36:46 pm »
Result :)
Tommo
