Date: 06-05-26  Time: 20:48 pm
Author Topic: C spanner in the 600 toolkit  (Read 3197 times)
mobile mouse
« on: 10 May 2013, 01:37:11 pm »
Hi,
About to upgrade my rear shock on my FZS600 foxeye from std to the FZS1000 shock with the 600 spring as described on the forum.
My question is:
Do I need to buy a different C spanner for the spring preload adjusting ring.
Or can I use the C spanner in the 600 toolkit to do the same job on the 1000 shock.
regards,
Andy FZS
Re: C spanner in the 600 toolkit
« Reply #1 on: 10 May 2013, 03:03:31 pm »
Sorry I can't answer your question but I'm interested in the modification, any chance of a review a couple of pictures once done.
Good luck
Andy
Sent from my GT-N8010 using Tapatalk 2
mobile mouse
« Reply #2 on: 10 May 2013, 04:03:03 pm »
Hi,
Find the info in the following link to a post started 12th Nov 2012.
I am following the instructions from wezdavo:
http://foc-u.co.uk/index.php/topic,5396.msg55109.html#msg55109
regards,
acid drop
« Reply #3 on: 11 May 2013, 03:11:09 pm »
if your c spanner is the same size then yes you can use it
Fuzzy
« Reply #4 on: 12 May 2013, 06:39:24 pm »
Would be interested to hear about how easy it is to change the preload on the thou shock (esp when on the 600).... harder than the standard shock?
wezdavo
« Reply #5 on: 12 May 2013, 08:38:23 pm »
Yes, a bit more of a pain when thou shock is fitted to the 600..
Fuzzy
« Reply #6 on: 12 May 2013, 08:50:09 pm »
Thanks wezdavo. That's a bit of a bummer though. I'm always taking different loads so easy adjustment of preload is a must. Standard 600 shock is quite easy to adjust, shame its such a budget item. I guess the only other alternative is a costly aftermarket shock with a remote adjuster  :(
