Date: 21-03-26  Time: 13:34 pm
Author Topic: what colour was your coolant last time you changed it?  (Read 13618 times)
markaboot
« on: 05 May 2013, 04:18:32 pm »
mine looked like this!  :eek
had to double check if it was water cooled or not, it looked like oil and smelt a bit like burnt caramel.
Re: what colour was your coolant last time you changed it?
« Reply #1 on: 05 May 2013, 04:34:49 pm »
Oh dear, that is oil, that ain't good at all.....  :eek
markaboot
« Reply #2 on: 05 May 2013, 04:41:19 pm »
thought so, doing a compression test now.
edit: no i'm not because i don't have the right adapter
« Reply #3 on: 05 May 2013, 05:09:05 pm »
look grim whatever it is. try taking one of the lower hoses off and run some water through it and see what comes out
markaboot
« Reply #4 on: 05 May 2013, 05:12:01 pm »
i flushed it all today, fresh water in. will run it a couple of times then flush again and put antifreeze in.
if was oil would i not have mayo in the radiator cap or worse on the oil cap?
i think its probably just really old coolant and well overdue a change.
« Reply #5 on: 05 May 2013, 05:21:46 pm »
Are you sure you didn't open the oil plug instead instead of the coolant bolt :'(
Not necessarily a compression problem, more than likely a water punp issue
« Reply #6 on: 05 May 2013, 05:47:39 pm »
I have a feeling this could be connected to your rattle?
And it wouldn't matter if your coolant was 10 years old, it still wouldn't be that colour or texture!!
markaboot
« Reply #7 on: 05 May 2013, 07:00:37 pm »
yea me too  :'(
« Reply #9 on: 05 May 2013, 07:35:31 pm »
Three posibilities Water pump , head gasket or oil cooler .
Most likely the water pump mechanical seal if  there is no coolant in the oil.
markaboot
« Reply #10 on: 05 May 2013, 08:29:35 pm »
yea oil looks ok from looking in the cap and window. very slight mayo on the cap thread, that normally i'd put down to condensation, im talking minimal amount, tiny tiny.
but then oil floats on water so any water would be in the bottom.
the coolant deff had an oily smell and feel on my fingers, but i've never seen oil and water mix without turning into mayo.
« Reply #11 on: 05 May 2013, 10:00:45 pm »
Is this the same bike with the rattle when hot? It is certainly pointing to the pump on both posts.
The noise sounds like the impeller knocking off the casing due to a knackered bearing which has damaged the seal.
« Reply #12 on: 05 May 2013, 10:03:58 pm »
Just read that the bearings can go on the impeller part of the pump.
I'd get your ear towards the water pump and get someone to rev the engine a little.
« Reply #13 on: 06 May 2013, 12:17:55 am »
I do believe thats what I said, water pump problem, if you read both threads
quiet when cold, rattles like mad when warm ??
They are related :wall
and no you cannot get bearings or seals for it, the complete pump needs to be replaced.
Since it does not happen to often it is worth taking a chance on a second hand pump.
« Reply #14 on: 06 May 2013, 06:36:12 am »
I know, and i do believe that i remember you posted as i was typing my answer at the same time.
And yes i know that he has the same name, the same bike, and i've been reading and commenting in both threads too, and i never mentioned buying bearings or seals for it, i was trying to pinpoint exactly where the actual fault was for starters!
Have a read and you'll see for yourself!  :wall :wall
Did we get a bit tiddly last night perchance?  :b
« Reply #15 on: 06 May 2013, 08:45:35 am »
Darrsi
Time for you to start reading the posts properly. :eek
You must be having one of you DARSSI moments  :pokefun
Go back an read them again. :z
« Reply #16 on: 06 May 2013, 09:46:41 am »
I've just seen this post, how long have you owned this bike?
Never seen this of on a Fazer before but on other bikes mainly race engines, somehow the coolant could been lost due to a leak or after doing some work i.e. loose pipe etc.  I've also seen it where debris has entered the system after major work or using an old watering can which jams the impeller and buggers the bearing.  The coolant is then lost through evaporation, oil enters via the buggered bearing/impeller shaft the bike is now oil cooled I will work but not for too long!
Fully and semi synthetic oil is that good today an engine can run with almost no loss of performance for a limited time with no coolant.  Bit of history here during WW2 most US carrier based aircraft engines where big radials, radials were mainly air cooled and preferred over water cooled engines at the time as they didn't have cooling systems that are venerable do battle damage.  The Pacific war was by definition fought over long range over water the planes had to get back to the carrier or ditch in the sea, risking loosing the pilot.
Battle damage often meant damage to engine oil tanks and possible total oil loss so they devolved oil additives (PTFE forerunners) slick 50 and such like, these would enable an engine to run without oil.  Which would keep the plane flying get the all important pilot/s back the the carrier the engine would be shot but they had plenty of them.
You need to do a major strip down to see what is going on with this engine or just get hold of a good second hand engine there are plenty out there.
« Reply #17 on: 06 May 2013, 09:58:55 am »
Just to answer the thread question, on both my Fazers the stuff that came out was luminous green and had the consistency of water. The stuff that's gone back in is more of a burnt orange colour - picked it up at Halfrauds
« Reply #18 on: 06 May 2013, 01:57:16 pm »
I just read somewhere else that "Bars Stops Leaks" which is a different brand of RadWeld can make coolant oily over a period of time.
« Reply #19 on: 06 May 2013, 02:12:31 pm »
If it could reliable change water into that sort of oil I'd be half tempted to put it in the engine haha :lol
In all seriousness though, that doesn't look as though its been changed / altered, it looks like it literally is and always has been oil :P
markaboot
« Reply #20 on: 06 May 2013, 02:26:43 pm »
Had the water pump out this morning, looks fine, no play its clean, seals look good. No obvious signs of water and oil mixing, no mayo.
The coolant level has never dropped nor has oil level. Its possible a previous owner used a very light oil as coolant or a dark orange coolant perhaps.
A compression test showed even cylinder pressures.
« Reply #21 on: 06 May 2013, 02:38:52 pm »
If all looks well i'd be inclined to use some RadFlush in the system and give the bike a good run, or leave it in the system for a couple of days then flush out and refill with proper coolant and see if it all seems okay?
edc
« Reply #22 on: 07 May 2013, 10:38:25 pm »
Mine looked just like that 2 years ago when I first changed the coolant after my first servicing.  I put it down to not being changed EVER in the 10+ years the bikes been around.
Coolant just changed.  This time the waste looked much better - no 'oil' etc.
Could be wrong though!  :lol
« Reply #23 on: 08 May 2013, 06:45:45 am »
I s'pose if a bike gets passed from inexperienced people to more inexperienced people over short periods of ownership then it's maybe possible that the fluids could be overlooked, but i'd have thought a mechanic doing an MOT would pick up on the colour of it in the expansion tank?
« Reply #24 on: 08 May 2013, 09:07:43 am »
I would have just assumed that the mechanics look at the level and figure its fine - you can't see very well the colour or viscosity through the expansion tank
