Date: 07-05-26  Time: 10:15 am
Author Topic: Taking the downpipes off any tips?  (Read 5501 times)
xlewisbdx
« on: 04 May 2013, 11:34:23 pm »
Just found out that my pipes have a crack in two places of what I know of. Any one ever taken them off and if so how easy is it?
Been told that the bolts can sometimes weld to engine and snap.
noggythenog
Re: Taking the downpipes off any tips?
« Reply #1 on: 04 May 2013, 11:41:54 pm »
From what ive read so far, folk spray the bolts with wd40 for at least a week before they even attempt to get them off but even then ive seen pictures of the studs snapping off, tbh with you if it was me i'd take my bike to a garage for this one as at least they'll have the tools if anything does go pear shaped & the bike wont be stuck at your house with the exhaust half hanging off.
but im not getting into the foc-u spirit & im sure lots will now say give it a bash and see what happens.
good luch :)
richfzs
« Reply #2 on: 05 May 2013, 12:11:16 am »
:wall for the umpteenth foccing time... Not wd40! Use a proper penetrating oil, plus gas, or the products made by 3in1 or wd40, that are designed specifically for the job. Wd40 (in the blue and yellow can) is good at what it was designed for - water displacement.
Sent from my Nexus 4 using Tapatalk 2
« Reply #3 on: 05 May 2013, 12:42:46 am »
:lol
noggythenog
« Reply #4 on: 05 May 2013, 03:02:26 am »
aw foc i tried typing 'penetrating oil as used by UB40 on their bikes'................... but the auto spell typed out wd40 :rolleyes
Honest Rich!!! :D
Chris
« Reply #5 on: 05 May 2013, 03:13:58 am »
Honest Rich!!! :D
 :rollin
Your search function broken again Lewis?  :lol
As the others have said: soak them in penetrating fluid for at least a few days first and then pray they don't snap, better get your lucky boxers on that day  ;)
Chris
Dave48
« Reply #6 on: 05 May 2013, 07:00:43 am »
The problem here is that the metal @ the exhaust ports gets extremely hot and when you ride in bad/wet weather all the crap gets thrown up on the front of the engine-mud/water/salt etc,which is an ideal recipe for corrosion. So unless you are fanatical about cleaning  the first time you notice theres a problem is when your exhaust starts to blow & you find the exhaust nuts refuse to budge. As said-spray around studs/nuts with PENETRATING oil-nothing else- for several days and if the nuts refuse to loosen-don't force them or you could end up with broken studs stuck in the cylinder.
If you run a search you will find this topic has been covered by many foccers-the main thing is not to rush at things-you could end up in a world of pain & expense! :eek
griff86
« Reply #7 on: 05 May 2013, 08:24:24 am »
I soaked mine in plus gas for a week and most of them still didn't budge.
I had to use oxy acetylene in the end to get them proper hot, came off nicely after that
If I was you I'd find someone with some oxy, also copper grease the studs when you rebuild them because you won't have any problems taking them off again if you do.
Skippernick
« Reply #8 on: 05 May 2013, 08:30:22 am »
To be fair Rich i used WD40 and it all went well, maybe i was lucky!!
Having said that Rich is right use a proper penetrating (uh er missies) oil. :lol
« Reply #9 on: 05 May 2013, 08:42:56 am »
Honest Rich!!! :D
 :rollin
Chris
Try searching for penentrating fluid not penentrating oil next time :pokefun
portboy
« Reply #10 on: 05 May 2013, 08:58:04 am »
Right now we have got the exhaust rings off how do we tackle the header assembly which has grown in with crud and corrosion ? :'(
