Date: 26-03-26  Time: 11:16 am
Author Topic: Side play in gear pedal 03 Foxeye  (Read 1688 times)
Dave48
« on: 26 April 2013, 08:15:47 am »
There is considerable side play between the pedal & footpeg shaft. Havent yet removed footpeg from alloy holding plate as bolt is corroded in. Does anyone know if  the pedal hole is fitted with a bush or just steel drilling operating on steel shaft? Have looked at my thou and there is hardly any lateral movement of the pedal resulting in nice slick changes.
Guess I will be trawling ebay for a replacement as I cant stand a sloppy gearchange!
Re: Side play in gear pedal 03 Foxeye
« Reply #1 on: 26 April 2013, 09:05:30 am »
Agreed, nobody likes a sloppy 2nd  :lol
« Reply #2 on: 26 April 2013, 12:39:39 pm »
Assuming it's the same as the earlier version, it is just a plain steel hole.
I added a steel washer to the shaft to cut down on the free play where the lever (and wafer thin spring washer) wears against the alloy hanger and also a rubber 'O' ring to try to keep rain/grit out and grease in. It's helped, but has now done about 80k so the lever and pivot could do with being replaced again.
Dave48
« Reply #3 on: 26 April 2013, 05:44:26 pm »
Update-managed to disassemble footpeg to discover the remains of a very thin wave washer that alledgedly takes up end float. have cleaned regeased and fitted thin washers either side of pedal shaft. Not perfect but more like a bike gearchange than a car now! Will replace worn parts in due course. :lol
« Reply #4 on: 26 April 2013, 09:31:20 pm »
I had the gear lever hole enlarged and a steel sleeve made to suit, fitted a new wavy washer and all was fine again  :)
