Date: 07-05-26  Time: 02:09 am
Author Topic: bike not starting  (Read 9673 times)
yamy
bike not starting
« on: 25 April 2013, 05:21:33 pm »
Hi all I'm in need of some help,  I've changed the starter
relay, starter and button to no good as to why it's not
Starting without abump start ?
any ideas what it could be?
Re: bike not starting
« Reply #1 on: 25 April 2013, 06:45:50 pm »
Bit more info needed, does it turn over using the button, is the battery okay, etc
yamy
« Reply #2 on: 25 April 2013, 06:58:48 pm »
hi  when button is pushed there's nothing (no clicking etc)
Battery is fully charged.
riz
« Reply #3 on: 25 April 2013, 07:01:03 pm »
Try starting with the clutch in
Orangegrump
« Reply #4 on: 25 April 2013, 07:04:19 pm »
Check the position of the red cut out switch on the right hand handle bar
yamy
« Reply #5 on: 25 April 2013, 07:29:07 pm »
Just tried all above and still nothing
« Reply #6 on: 25 April 2013, 07:46:54 pm »
Time to check for bad connections to the starter motor. Use a multimeter and see if you are getting power whilst thumbing the starter button
John Silva
« Reply #7 on: 25 April 2013, 07:50:19 pm »
Have you checked all the fuses.
yamy
« Reply #8 on: 25 April 2013, 07:59:39 pm »
All  fuses checked and are ok.all wires feel fine.
Just thinking could it be the immobiliser playing up but starts with bump through.
yamy
« Reply #9 on: 25 April 2013, 09:30:18 pm »
is there a fuse just for the starting ? apart from on the relay
yamy
« Reply #10 on: 26 April 2013, 08:58:24 am »
Just a update just been out to it and it started first time
Ruby Racing
« Reply #11 on: 26 April 2013, 09:09:52 am »
So perhaps you have an intermittent problem? Now that's the worst kind.  :(
clayt74
« Reply #12 on: 26 April 2013, 04:15:51 pm »
A bit like when I asked the missus if my indicators worked and she stood watching sayiny yes......no........yes.....no........yes  :lol
Exupnut
« Reply #13 on: 26 April 2013, 04:20:08 pm »
Lmao hahaha
« Reply #14 on: 26 April 2013, 05:26:03 pm »
As always, it can be a broken wire or corroded connector, a careful visual check of the bundle in the plastic box under the tank and by the battery compartment may show the problem. Otherwise it could be the starter cut-out relay.
yamy
« Reply #15 on: 26 April 2013, 09:02:45 pm »
cheers bud but where is the starter cut out relay
« Reply #16 on: 26 April 2013, 10:47:42 pm »
It's near the starter relay, lift the seat and take the left hand side panel off, it's the one with a connector with 11 wires.
yamy
« Reply #17 on: 27 April 2013, 08:06:25 am »
Cheers bud will look at it and see what's going on
yamy
« Reply #18 on: 27 April 2013, 10:28:15 am »
Looks clean but got one on order now 15 quid
« Reply #19 on: 27 April 2013, 11:34:33 am »
Hope that solves it.
I would have poked around with a multimeter to check it's faulty before splashing out... but I am a skinflint. :lol
yamy
« Reply #20 on: 27 April 2013, 10:30:52 pm »
will do that tomorrow now cheers
yamy
« Reply #21 on: 30 April 2013, 02:26:03 pm »
hi  I've tried everything so far. What about putting a switch
to the relay near the battery cos it starts by doing that
would it do any harm ?
« Reply #22 on: 30 April 2013, 11:52:50 pm »
Perhaps we can pin it down rather than bodging a solution.
If changing the cut-out relay hasn't cured things that just leaves the wiring and connectors as suspects doesn't it? I think you've changed everything else.
Might be worth checking the voltage at the black wire on the cut-out relay... with everything ready to go it should be at 12v, and drop to 0v while you thumb the starter button.
yamy
« Reply #23 on: 01 May 2013, 02:38:15 am »
Cheers mate I'll give that a go at the weekend. If not it's going to be a shop bill
to get this sorted can't be bumping it for ever.
« Reply #24 on: 03 May 2013, 11:36:33 am »
Another thing you might try: hold the starter button down whilst slowly turning the bars from one side to the other. If there's a broken wire that sometimes makes contact it's quite likely to be at the point where the cable bundle flexes.
