Date: 26-03-26  Time: 05:34 am
Author Topic: How much should front brake pads cost?  (Read 18413 times)
Re: How much should front brake pads cost?
« Reply #25 on: 25 April 2013, 06:54:24 am »
Just noticed that no one has actually answered the thread question.
Depends on the pads. But decent pads seem to go for about £12-£18 a set depending on where you buy them from and the make etc. The SBS Ceramics I like are about £15-16 a set :)
I answered the question earlier!  :book
« Reply #26 on: 25 April 2013, 07:03:42 am »
2 things you have said ring alarm bells.
Firstly if you can feel it through the handlebars it could aim towards head bearings, OR what ended up being my problem was a faulty/old braided brake line, which caused a "juddering" feeling on braking, which just happened to be the only thing left for me to try changing to cure it.
Because it was braided i simply didn't think it would've gone wrong.
Now i know better.  :'(
Secondly, you said you have to pump the brakes a couple of times (and you feel it through the bars).
This could point at a disc problem.
If you get any warping of a disc, when you are moving it will spread the pads further apart than normal, which can result in having to pump the brake one or two times to bring them back to react, then because the disc isn't flat it can create a pulsing effect through the brake lever.
Really not good in an emergency, it will frighten the life out of you when you do a panic stop and you get a handful of sponge.
So at the moment i doubt very much it's just a simple pad issue by the sounds of things.
But you need to eliminate things one at a time.
Start with the real easy stuff like are the caliper bolts done up correctly, bleed the brakes, clean/grease the front brake lever joint, etc.
If i have pads for you i'll clean them up at work for you, i'll let you know soon.  :)
richfzs
« Reply #27 on: 25 April 2013, 07:14:41 am »
Quote from: darrsi
[/quote
Nothing on this thread you didn't! I can't see it, anyways...
Sent from my Nexus 4 using Tapatalk 2
« Reply #28 on: 25 April 2013, 07:25:30 am »
Quote from: darrsi
[/quote
"....SBS seem to be the most popular choice on here, with very good references, and they're not even expensive oddly enough!...."
WAKEY WAKEY :lol
« Reply #29 on: 25 April 2013, 07:31:32 am »
"...not expensive..."    that's a price isn't it?  :lol
richfzs
« Reply #30 on: 25 April 2013, 07:41:01 am »
More of a value range :-)
« Reply #31 on: 25 April 2013, 09:04:26 am »
Looks like your lucky day Lewis, i found a very nice pair of pads for you, they look like new.  :)
Only problem is that if you get to really like them i can't actually tell you what make they are for you to get them again?  :rolleyes
But i can promise you they weren't a crappy make 'cos i was trying different brands out when i had my braking problem and remember prices getting more expensive as i was trying to solve it.  :\
They're in the post, you should have them tomorrow, i just need to sweet talk the receptionist first :D
Dead Eye
« Reply #32 on: 25 April 2013, 09:33:12 am »
For the sake of proper referencing, these are the pads I bought for the front - I also upgraded to HEL braided lines (this was all just before the great fire of 2012 :()
http://www.ebay.co.uk/itm/SBS-FRONT-BRAKE-PADS-YAMAHA-FZS-600-FAZER-1998-2003-CERAMIC-/150791446789?pt=UK_Motorcycle_Parts&hash=item231bdee105
Dave48
« Reply #33 on: 25 April 2013, 09:53:29 am »
Plenty of wise counsel on this topic already. I take the point that money is tight. The owner who regularly checks his/her bike & follows a service schedule will avoid a lot of unnecessary expense/heartache down the line. You describe more than one "symptom" of problems so back to basics. start with your tyre/wheel/brake discs. Next the brake callipers/hoses/master cylinder/brake fluid. Next your fork action(do you know if/when the fork oil was changed?) Next your headset bearings. I see you have a 98/99 bike-did it come with service history?
I have just bought an 03 Foxeye with most old MOT certs but no service record SO I got out Mr Haynes & am systematically working through ALL the service items. Now Yamaha recommend changing the rubber brake hoses every 4 years-mine are rubber so am ordering a set of braided hoses. They also recommend changing all the rubber seals both in the calipers & also the master cylinder internals every 2 years. If  you have to spend a bit of money remember its a small price to pay for peace of mind(there are insurance implications as well if your bike is found to be unroadworthy after an accident)-Brakes & Tyres don't cut corners & compromise your safety :eek
xlewisbdx
« Reply #34 on: 25 April 2013, 10:16:27 am »
I haven't a clue when the forks was last serviced. The bike came with a part service up to 18,000 miles. The bike is now on 29,000. How simply is it to upgrade to braided hoses and how much am I looking at spending while doing it? The rubber seals where last checked in Septemeber 2012. I have no clue when the master cylinder was last checked.
Even if the problem isn't in the brakes it sound like a good idea to upgrade to braided hoses anyway.
Not sure how I would bleed the brakes I would have to get a haynes manual. ( I have the downloaded one)
xlewisbdx
« Reply #35 on: 25 April 2013, 10:17:12 am »
You sir should have a medal. Thank you :-)
Dave48
« Reply #36 on: 25 April 2013, 10:57:39 am »
 :lol I think Yamaha err on the side of caution when it comes to master cylinder internals-I have previously changed these at recommended interval-only to find no visible signs of wear on the rubber seals. However with a 14/15 year old bike they will have seen a lot of action so something to consider. Rubber brake hoses deteriorate structurally and eventually weaken so will bulge under braking pressure reducing brake force to pistons & reducing "feel" at lever. The cheapest option for front is to order two lines that run from master cylinder one to each wheel-avoiding the "splitter" that sits on the lower fork yoke.  Always some good deals on Hel lines on ebay. It is best to buy Yamaha seals for the brake pistons as they will always fit unlike some makes of pattern seals!
If you are relatively new to all this maintenance stuff-ask on the forum if  theres any members in your area who could lend a hand. Im a bit far away in theWest Mids unfortunately. What I can offer is a 50gm pot of red rubber brake grease-for the pistons that is!. just send me a PM with your address. Good luck :lol
elbrownos
« Reply #37 on: 25 April 2013, 10:59:20 am »
What's the story with braided hoses?
I understand they make your brakes feel stiffer. I reckon my brakes feel fine (I don't ride hard) so this is not a big deal for me.
Presumably they are more expensive than rubber hoses and are more inclined to corrosion (the braiding is usually galvanised steel wire no?).
Does anybody install rubber hoses any more?
xlewisbdx
« Reply #38 on: 25 April 2013, 11:06:04 am »
Just had a look on eBay for some braided hose lines. I would like the orange ones as they will go with my bike ;)
So am i right in thinking this is the front [size=78%]http://www.ebay.co.uk/itm/Venhill-brake-line-kit-for-Yam-FZS-600-Fazer-97-03-race-design-stainless-braided-/200745837708?pt=UK_Motorcycle_Parts&hash=item2ebd62648c[/size]
and this is the rear [size=78%]http://www.ebay.co.uk/itm/Venhill-brake-line-Yamaha-FZS-600-Fazer-1998-03-rear-stainless-braided-/200710958081?pt=UK_Motorcycle_Parts&hash=item2ebb4e2c01[/size]
Will they be good enough for the job?
Edit: I could always ring my local bike mechanic up and ask him to bleed the front brakes and take a look at them and make sure they work as they should. I'll tell him the symptoms I have told you guys. I'm sure he'll know what to do and eliminate the problem one by one and fot the braided lines.
Dave48
« Reply #39 on: 25 April 2013, 11:07:17 am »
elbrownos-braided lines are made from stainless steel with an outer coating-either clear or coloured. They don't bulge under pressure so transmit the fluid pressure from lever to pistons more effectively than rubber that deteriorates with age/use. So although perhaps dearer they generally last a long time. Tip. Don't fit alloy bolts(race fittings)-they will corrode with road salt.  :'(  Use stainless. :lol
Dave48
« Reply #40 on: 25 April 2013, 11:10:38 am »
Venhill reputable supplier. That's the set up you want . Are Hel or Goodridge any cheaper?
Dead Eye
« Reply #41 on: 25 April 2013, 11:13:23 am »
I was looking in to HEL lines this morning, then decided that the measly £6 in my bank account was going to cut it :P
Cheapest set I found was £52 delivered on eBay :) Had them before and the completely changed the feel of the brakes. So much more powerful and easy to control. Having said that I never used to have any issues on my old '99 model. Current one has once or twice left me feeling like I wasn't going to stop in time and that wasn't under extreme circumstances either. Felt more like brake fade but I hadn't previously been grabbing at the brakes. In any case, I'll sort it all out once I have the money.
Bleeding the brakes is simple enough;
1. Fill reservoir
2. Open bleed nipple
3. Pull brake lever
4. Close bleed nipple
5. Release brake lever
6. Repeat until no more air comes out
If brakes don't feel hard enough, continue bleeding. One other option is to zip tie the lever and leave it overnight and try again :)
First time I did this on the bike I didn't have a hose or anything so just used an old rag to catch the fluid coming from the bleed nipple. Second time round was on my car after a brake line failed whilst on a dual carriageway approaching a roundabout a bit fast (that was NOT fun!). Using some clear pipe was definitely easier
Dead Eye
« Reply #42 on: 25 April 2013, 11:15:00 am »
Venhill, HEL, Goodridge are all good names :)
Try and do the work yourself, its simple and will save you a fortune on labour if you are tight for cash!
xlewisbdx
« Reply #43 on: 25 April 2013, 11:27:20 am »
So am I right in thinking I am bleeding one caliper at a time?
Dead Eye
« Reply #44 on: 25 April 2013, 11:31:49 am »
That's right, one calliper at a time :)
xlewisbdx
« Reply #45 on: 25 April 2013, 11:34:39 am »
I'll get some brake fluid and spend a little time with it at weekend. Those two link I posted, the front brake will I need to order two front brake ones are just the one?
Dead Eye
« Reply #46 on: 25 April 2013, 12:20:23 pm »
Order just the one as its a set and provides both front lines :)
Obviously the new "race" setup that you order is two lines that go direct from the Master cylinder straight to each calliper, whereas the existing setup has 3 lines (join in the middle). The race setup is cheaper and probably easier to deal with as well :) As always, any questions, ask away :D
« Reply #47 on: 25 April 2013, 12:25:29 pm »
Unless you're me and get a faulty braided line that caused juddering and a world of pain  :'(
I've yet to see any complaints by anyone else about them though, which is probably why i was looking elsewhere for a fix because there wasn't any info online about them failing, but they are definitely way superior to standard lines.
Chris
« Reply #48 on: 25 April 2013, 04:49:16 pm »
If you're going to be changing brake lines and or bleeding your brakes then make sure you know what you're doing or you may not be able to stop when you get out on the road.
I found this video helpful
Delboy's Garage, Harley Sportster Brake Hose Change.
Be good to have a friend who knows what they're doing there to help too  ;)
Take care,
Chris
« Reply #49 on: 25 April 2013, 06:59:48 pm »
The pictures seem to indicate that there is loads of life left in those pads imo
I'd suggest your problem is elsewhere.
ChristoT recently had an issue with his front brakes squeaking a lot so when he was round mine the other day, we removed the callipers, removed the pads, put some copper grease on the back and reassembled and now the squeak is completely gone. You can get a massive pot of copper grease for less than one of those cheap sets of pads you found
The squeak is gone indeed!
But I now get a strange whooshing noise at about 37mph, most noticeable if I'm coasting. And I haven't a clue as to what's causing it...  :wall
Are you running standard or non standard discs?
