Date: 26-03-26  Time: 02:38 am
Author Topic: How much should front brake pads cost?  (Read 18363 times)
riz
Re: How much should front brake pads cost?
« Reply #50 on: 25 April 2013, 07:07:24 pm »
Dont forget when playing with brake fluid, it eats through paint, so if you do spill any on paintwork then clean it off really well.
When bleeding the brakes on a fazer do you need to unbolt the caliper and rotate it to get all the air out?
« Reply #51 on: 25 April 2013, 07:29:50 pm »
Just keep bleeding it until it looks like all the air has gone, but having the brake lever pulled in overnight can work wonders if you're still not 100%.
gerkin
« Reply #52 on: 25 April 2013, 08:56:39 pm »
ebc hh £36 on ebay inc delivery
xlewisbdx
« Reply #53 on: 26 April 2013, 08:53:07 pm »
Good news! The squeeking/crunching noise has gone. I put some copper grease on the back of the pads.
I will await the arrival of the second set of pads from Darrsi (The Legend that he is) and I will then bleed the brakes tomorrow :)
Dead Eye
« Reply #54 on: 26 April 2013, 08:59:04 pm »
Glad to hear it! Giving the calipers a good clean won't do any harm though ;)
« Reply #55 on: 26 April 2013, 09:14:29 pm »
Yeah, bit of a faux pas on my part, for some reason i had rear brake in my mind and only sent him the one pair of pads!!
Other pair is en route, special delivery  :)
xlewisbdx
« Reply #56 on: 26 April 2013, 09:16:09 pm »
Will be doing tomorrow before I bleed them :)
You're still the man :)
xlewisbdx
« Reply #57 on: 27 April 2013, 01:27:38 am »
Going to order some new front brake seals. When fitting them is there any special way? I watched a video on how to split and replace the seals and the guy mentioned that they need to go in a certain way. For example when the seal is in you should feel the lip as you move your finger out. Is this the same with the Fazer or not?
« Reply #58 on: 27 April 2013, 12:02:55 pm »
Smear the seals with red rubber grease when putting them in, and give the grooves they sit in a good clean with a toothbrush, preferably using brake cleaner.
