Date: 25-05-26  Time: 20:32 pm
Author Topic: digi gear indicator  (Read 2145 times)
slimwilly
digi gear indicator
« on: 18 April 2013, 05:28:40 pm »
Mine has stopped, no digits displayed, where will it be wired to to remove it?
richfzs
Re: digi gear indicator
« Reply #1 on: 18 April 2013, 05:32:19 pm »
Is the answer not as obvious as following the wiring from the back of the display?
Sent from my Nexus 7 using Tapatalk 2
Ian-man
« Reply #2 on: 18 April 2013, 06:46:32 pm »
My digi is wired into the loom behind the clocks, take your screen off and you should be able to see it.
Sent from my HTC Sensation Z710e using Tapatalk 2
slimwilly
« Reply #3 on: 18 April 2013, 08:21:28 pm »
Not that easy to follow the wires,
The screen on it is blank, dont know how reliable these things are, its a well known make too.it was fitted when i bought it,i am just worried that it could cause problems left joined up.
If it hooks up in the dash cluster then i guess i could unhook it.
ghostbiker
« Reply #4 on: 18 April 2013, 09:44:43 pm »
Might be a plug and play like mine. Unplug then re join the normal conectors
If not then it will be hard wired in, still simple to remove though.
