Date: 11-05-26  Time: 12:41 pm
Author Topic: Leaking Coolant pipes?  (Read 2044 times)
Jimmygixxer
« on: 14 April 2013, 03:06:47 pm »
I got my engine put back in the fazer last week. I then noticed that there was a coolant leak from one of the metal pipes which sits inbetween the inlet rubbers. :\
So i took the carbs back out and fitted another same size oring seal to the pipe and reassembled. Seamed to cure it.
But today i noticed its leaking again and the other one beside it is doing it now as well.
What is the proper fix for this?
Do i need to get the biggest o ring on it i can because the one bolt that holds the pipe to the engine doesnt exactly push it very tight into the engine.
Kage7
Re: Leaking Coolant pipes?
« Reply #1 on: 14 April 2013, 04:27:21 pm »
Either pop to a hardware store and get the correct size o-ring, or better yet pop to a Yamaha dealership and get the part there, i'm sure they're not too much (part number 93210-15414). Also ensure that the bolt holding the pipes onto the head are correctly torqued (i.e. not loose)
Jimmygixxer
« Reply #2 on: 14 April 2013, 07:29:07 pm »
The new one i fitted was the same size as the yamaha one which came out and the bolts are correctly tightened?
