Date: 11-05-26  Time: 04:34 am
Author Topic: Rear Axle bolt  (Read 2415 times)
Notch000
Rear Axle bolt
« on: 13 April 2013, 06:53:31 pm »
Can anyone tell me what size the rear axle bolts  are?  My socket set only goes to 20mm which is too small so need to get a new socket head to tension chain
limax2
Re: Rear Axle bolt
« Reply #1 on: 13 April 2013, 07:01:05 pm »
Nut is 27mm across flats and the spindle head is 24.
Notch000
Re: Rear Axle bolt
« Reply #2 on: 13 April 2013, 07:06:04 pm »
any idea what that is in socket, spanner size
limax2
Re: Rear Axle bolt
« Reply #3 on: 13 April 2013, 07:16:15 pm »
A socket or spanner will be marked "27mm" and "24mm".
I wouldn't use an open ended spanner but a ring spanner would be o.k. except you can't tighten it to the correct toque with one.
You should use a socket and torque the nut up to 117Nm.
In the absence of a torque wrench that is best described as jolly tight.
