Date: 11-05-26  Time: 08:57 am
Author Topic: idle speed adjustment.  (Read 3351 times)
john 087
« on: 09 April 2013, 03:20:29 pm »
 HI All, I have a 98 Fazer the idle speed is a bit high at 1500 rpm, the cable that adjusts it is seized, is there any other way to bring the idle speed or would I be better and just leave it alone as the bike is going well. It has almost 58000 miles on it.
Many Thanks.
John
reillypadraig
Re: idle speed adjustment.
« Reply #1 on: 09 April 2013, 04:18:58 pm »
Not much you can do without remove the carbs I think, removing there won't do any harm as long as you get as good of seal on the airbox and intake headers as is already on it, then you will have a good grasp on the adjuster. Maybe if you have the time or patience the carbs might need a good cleaning, depending on how long it's been since they were cleaned but if its running sweet as a nut maybe best to leave well alone, up to you but that's what I would do after going to all the bother of taking the carbs out, hopefully a little gentle persuasion might free it(hammer  :D)
john 087
« Reply #2 on: 09 April 2013, 04:48:35 pm »
I have the bike over 3 years and the carbs were never touched, I think i will leave it alone as the bike is going well.
Many thanks.
His Dudeness
« Reply #3 on: 09 April 2013, 04:57:26 pm »
If you can lift the tank you might be able to get some wd40 down onto the end of the idle adjuster.
john 087
« Reply #4 on: 09 April 2013, 05:11:52 pm »
will try that as its due a service soon and i have to change the fuel filter.
AdieR
« Reply #5 on: 10 April 2013, 03:21:59 am »
If it's running ok, I'd leave it be for now.
packie
« Reply #6 on: 10 April 2013, 09:50:48 am »
Same here...you could bring on more trouble than what it's worth.
alexanderfitu
« Reply #7 on: 10 April 2013, 07:35:02 pm »
To adjust the idle, you twist the big thumb wheel on the left hand side of the carbs. The thingy on the throttle is only for cable slack :)
