Date: 28-03-26  Time: 15:20 pm
Author Topic: Luggage rack Mk1 V Mk2  (Read 1641 times)
Notch000
« on: 05 April 2013, 11:50:14 pm »
Ive been offered a luggage rack for the fazer, the one in question is for a 2001-2003 model, my bike is Mk1 1999, Ive read somewhere that the only difference is the footpegs and  I will need to swap these for a 2001 set ??  that should be easy enought to organise, I cant find that information again now, does anyone know if this is true ???
richfzs
Re: Luggage rack Mk1 V Mk2
« Reply #1 on: 06 April 2013, 12:23:39 am »
Yeah, the pillion pegs are lower from 2000 on (so use longer hangers, if that makes sense?)
Sent from my Nexus 4 using Tapatalk 2
« Reply #2 on: 06 April 2013, 12:38:59 am »
Google FZS600 differences
Notch000
« Reply #3 on: 06 April 2013, 02:40:44 am »
2000
. Pillion comfort improved: Rear pegs lowered 45mm & moved forward 10mm and pillion seat padding increased by 16mm.. Pillion pegs redesigned to remove 'barb' from handhold/luggage-retention projection and the 'eyelet' hole is reduced in size. Pillion pegs are now rubber coated also.
So are the pegs a direct swap, i.e same mounting points used ?
Notch000
« Reply #4 on: 07 April 2013, 09:47:57 pm »
Bump
Are the exhaust hangers different too ???
