Scottoiler for sale £65 + £6 p&p. The Touring Kit has all the advantages of the vSystem and Universal Kit with an increased oil capacity of seven times, enough for between 4000 and 6000 miles riding, depending on the flow rate setting. The High Capacity Reservoir mounts behind the rear number plate and the RMV (Reservoir Metering Valve) can be attached directly to the side of it, or mounted remotely if preferred.side of it, or mounted. kit has been used but in good condition.
