Date: 03-04-26  Time: 15:40 pm
Author Topic: Compression Tester Size  (Read 8101 times)
humbucker88
« on: 02 April 2013, 09:35:02 pm »
My bike is of poor health, I recently replaced the head gasket as it was burning coolant but to no avail, runs a bit better now ive corrected the valve clearances and overhauled the carbs but still burning coolant. I'll probably buy a "new" head and see if that solves the problem but first I'd like to get a compression tester to pindown the cylinder(s) that's burning coolant.
Looking online the majority of kits fit spark plugs 16mm and 21mm, the NGK CR8E has a 10mm diameter but a 16mm hex size... I have no idea which of these the kits are refering to?
Here's an example:
http://www.ebay.co.uk/itm/PETROL-ENGINE-CYLINDER-AUTOMOTIVE-COMPRESSION-DUAL-TESTER-TOOL-KIT-/130760378531?pt=UK_Diagnostic_Tools_Equipment&hash=item1e71ed08a3
Would really appreciate any help, am at my wits end!
AdieR
Re: Compression Tester Size
« Reply #1 on: 03 April 2013, 03:55:11 am »
I would say the smaller size.
Has your bike overheated recently?
I would hazard a guess and say a blown head gasket, if it's been running overly hot, your head may be warped too.
If you remove the head, any damage to the gasket will likely be obvious without a compression test.
« Reply #2 on: 03 April 2013, 06:55:45 am »
hi humbucker88.....i bought one for my 600 last year....i`ll dig it out tonight and let you know the size....think it was a GUNSONS product  ;)
humbucker88
« Reply #3 on: 03 April 2013, 02:53:00 pm »
That'd be great cheers!
Yeah I replaced the head gasket and it wasn't damaged, I think the person before me replaced it too in hopes of fixing the problem, hence why it wasn't damaged. So i'll be replacing the head at the weekend and crossing my fingers!
John Silva
« Reply #4 on: 03 April 2013, 03:54:09 pm »
I think I brought a M10 adaptor for my Gunson tester a few year ago for my bike.
This one on ebay has all sizes included. LINKY
humbucker88
« Reply #5 on: 03 April 2013, 05:06:25 pm »
Ye i'll go for the 10mm adaptor, although I'm a bit suspicious of such a cheap price, it seems almost....too cheap? lol
« Reply #6 on: 03 April 2013, 09:18:07 pm »
yep........10mm is the one that you want,i already had a compression tester so i just bought an adaptor from GUNSONS less than £10 if i remember  ;)
humbucker88
« Reply #7 on: 04 April 2013, 05:01:17 pm »
Awesome, cheers dude!
inditime
« Reply #8 on: 16 April 2013, 09:46:43 am »
I bought the kit Humbucker posted a while back, not realising that my bike has smaller spark plugs. Is the adapter that will fit this kit the 10mm red98 is talking about. I couldnt find it when i googled gunsons.
« Reply #9 on: 16 April 2013, 03:17:20 pm »
i`ll try and post a picture of the adapter and my compression tester when i get in tonight  ;)
« Reply #10 on: 16 April 2013, 08:56:48 pm »
well the picture posting did`nt work :o ........i can tell you it was a LASER product and not GUNSONS as i had first thought,its two adaptors in one , converting a standard compression tester to either 10mm or 12 mm...hope this helps  ;)
John Silva
« Reply #11 on: 17 April 2013, 06:46:49 pm »
inditime
« Reply #12 on: 19 April 2013, 11:17:52 am »
Thanks all. My daughters b/f is bringing over a compression set tomorrow, he is a mechanic and says there is fittings for 10 and 12 mm so should be ok.
gerkin
Dead Eye
« Reply #14 on: 10 July 2013, 10:39:44 pm »
Haven't used this exact product, but most of the Laser stuff I have used has been ok - its not top notch stuff, obviously, but its not a pile of crap either :)
« Reply #15 on: 11 July 2013, 06:44:51 am »
thats the one i have,very pleased with it,very good quality and and easy to read gauge.all the adapters you will ever need and at a great price......i have a few laser products and no complaints  :D
gerkin
« Reply #16 on: 15 July 2013, 05:13:05 pm »
how did you screw thw adaptor in my socket wont fit between the cylinder hesd castings ?
« Reply #17 on: 15 July 2013, 06:43:39 pm »
What exactly do you mean by burning coolant?
If we knew what you meant then we can point you in the right direction before you talk about replacing heads and head gaskets.
It it using coolant or overheating or what exactly
« Reply #18 on: 15 July 2013, 06:49:00 pm »
This post is from April 2nd, i would imagine something's been done about it?
« Reply #19 on: 15 July 2013, 09:11:31 pm »
Did not read the date, woinder what the problem was? :rolleyes
