Date: 12-05-26  Time: 04:27 am
Author Topic: always hard to start (she breathes fire and demands miles as a sacrifice)solved  (Read 16034 times)
Ruby Racing
Glad she is fixed and working after all that, if it happens again check the reg/rectifier? If its not giving the battery the right charge it will bollox the battery eventually that's where the last battery was dying and at the bike on idle it's running on the battery, not enough charge from the generator until about 2,500-3000 rev to re-charge, I'm open to be corrected on this but worth a look after you spent so much on replacing everything else
I agree, check the R/R in case it's goosed and takes out your new battery.
carrier
It was probably the shorting out every single wire when they tried to hot wire it, that killed the battery. Even above 3000 it would die.... didn't matter where the rpm was it would die.
