Date: 25-04-26  Time: 18:14 pm
Author Topic: Fazer 1000 gen 1.. FORK OIL...talk to me!  (Read 9954 times)
jonjenk
« on: 31 March 2013, 05:47:12 pm »
I have a mint 2001 FZS1000 with only 11k on the clock. As it is 13 year old I've decided to change the fork oil. I emptied the tubes and some smelly grey stuff came out so i'm glad I decided to change it. I need to re-fill the tubes...
Can anyone give me any advice on the weight of oil and the quantity/air gap to improve the forks without changing the springs?
If I were to replace the springs what would be the best/most cost effective way of improving the forks?
I have just fitted a brand new original shock to the bike.
Thanks,
JOHN
kebab19
Re: Fazer 1000 gen 1.. FORK OIL...talk to me!
« Reply #1 on: 31 March 2013, 06:27:07 pm »
2.5w oil helps suppress the harshness a good bit. I replaced my springs with those from an XJR1300 to cope with the extra weight.
Other options are rebuilding them with aftermarket cartridges such as those made by k-tech or fitting other forks.
Mike (Falcon) went with  USD R1 forks & yokes which are great.
http://fazer1000.yuku.com/topic/3408#.UVhxSTeAZcM
I went with R6 2003 RWU forks which fit the standard Fazer yokes.
http://fazer1000.yuku.com/reply/23677/Re-R6-forks-nonUSD-for-Gen1#.UVhxZjeAZcM
sadlonelygit
« Reply #2 on: 31 March 2013, 08:35:33 pm »
i firstly went with a respring and re-oil and now have an R1 front end.
firstly, what weight are you, that will determine if you need a respring.
secondly, as has been said a lighter oil gives a smoother damping action, but you need to experiment with air gaps as the rebound is a lot softer.
jonjenk
« Reply #3 on: 31 March 2013, 08:42:50 pm »
I'm around the 16 stone mark (but the missus would like me to be 13) and although I don't often carry a passenger, I do carry luggage on trips.
Other posts on here talk about using 10w oils and specify air gaps... All I'd like is to get a good feeling, well damped and sprung front end using as much of the original bike as possible.
sadlonelygit
« Reply #4 on: 31 March 2013, 08:50:06 pm »
0.95 or 1.0 kg/mm linear spring
5 or 2.5wt oil 140mm air gap or 440cc per leg.
don't forget to bleed the suspension
jonjenk
« Reply #5 on: 31 March 2013, 09:03:55 pm »
Bleed suspension??? enlighten me please
Exupnut
« Reply #6 on: 31 March 2013, 10:14:44 pm »
Its all bollocks if u have a good mechanic
Sent from my iPhone using Tapatalk 2
jonjenk
« Reply #7 on: 31 March 2013, 11:34:22 pm »
Very helpful. Thanks.
Exupnut
« Reply #8 on: 01 April 2013, 07:45:34 am »
Then try something like this. http://www.ovalmotorcyclecentre.co.uk/web/index.php
Dont know where u r but if u could find somethin similar its worth it.
Exupnut
« Reply #9 on: 01 April 2013, 07:46:18 am »
Thanks. Lol
sadlonelygit
« Reply #10 on: 01 April 2013, 02:06:21 pm »
download a manual, far easier than me explaining it to you.
Tmation
« Reply #11 on: 01 April 2013, 02:42:07 pm »
And you can download it from here. http://foc-u.co.uk/index.php?action=downloads;cat=4
