Date: 22-03-26  Time: 08:07 am
Author Topic: cdi/ecfu unit  (Read 3324 times)
fazerblue
cdi/ecfu unit
« on: 30 March 2013, 03:26:53 pm »
My cdi/ecu unit needs replaceing when I checked out the net to buy one two different part numbers came up one is 5lv-82305-00 and the other is 5lv-82305-40 every one is advertising them both as suitable for all fzs1000 2001-2005 does any one know if this is true or are they persiphic to individual machines many thanks for any help.
Re: cdi/ecfu unit
« Reply #1 on: 30 March 2013, 05:13:47 pm »
I think they're different.  Off the top of my head, I seem to recall one type has a single electrical connector, while the other has two.
Unfortunately, none of the fiches I looked at made it any clearer but I suggest you check the number of connectors plugging into yours and at least ensure that the replacement has the same. :)
fazerblue
Re: cdi/ecfu unit
« Reply #2 on: 30 March 2013, 05:26:08 pm »
I believe the unit with 2 connectors fits the r1 and the unit with 1 connector fits the fzs1000 although they have different model numbers I have been told they will be ok for all fzs1000 years 2001-2005 would just like to be sure
Re: cdi/ecfu unit
« Reply #3 on: 31 March 2013, 08:24:06 am »
You're probably right about the R1 / FZS1000 ECUs.  My bad ... I've got a '99 R1 in the garage which is perhaps why I got them confused. :)
devilsyam
Re: cdi/ecfu unit
« Reply #4 on: 31 March 2013, 08:48:49 am »
seem to recall there was an issue fitting later ones because of the daytime lights on from bike 03 onwards
this wouldnt work with pre 03
fazerblue
Re: cdi/ecfu unit
« Reply #5 on: 31 March 2013, 03:20:59 pm »
Iam looking at getting one from a 2003 bike but it has the same part number what do you think?
AdieR
Re: cdi/ecfu unit
« Reply #6 on: 03 April 2013, 04:16:08 am »
Daft as it may sound, why does your ECU require replacement? They aren't items that normally fail.
Re: cdi/ecfu unit
« Reply #7 on: 03 April 2013, 06:37:13 am »
is there a part number on your old ecu ?
