Date: 25-04-26  Time: 06:27 am
Author Topic: Indicator flash speed problem  (Read 2360 times)
brooker81
« on: 30 March 2013, 12:57:17 pm »
Went out on the bike today it was first time in month after breaking ribs, anyways the right hand indicator flashes fast the left normal speed and when the hazards are on normal speed I'm baffled any ideas ?
stevierst
Re: Indicator flash speed problem
« Reply #1 on: 30 March 2013, 01:09:54 pm »
Blown indicator bulb is the normal sign.
brooker81
« Reply #2 on: 30 March 2013, 01:18:06 pm »
They are all still working  :\
ghostbiker
« Reply #3 on: 30 March 2013, 01:53:40 pm »
Working with little info here but have you replaced a bulb with a led bulb at any Pont?
brooker81
« Reply #4 on: 30 March 2013, 02:00:10 pm »
Nope nothing like that the only thing I can think of is replacement bulb isn't same wattage ? I only tested on hazard so that may be why I didn't detect it
DekF
« Reply #5 on: 30 March 2013, 02:02:15 pm »
If they all flash at the normal rate when on hazard & the same rate when on left turn it means it can only be the contacts in the switch.
Try some contact cleaner or WD40 & spray liberally into the switch & be aggressive with the switch action. It should clear up.
brooker81
« Reply #6 on: 30 March 2013, 02:52:29 pm »
Ill give that a try thanks
