Date: 24-04-26  Time: 10:29 am
Author Topic: service for my 98 fazer  (Read 3030 times)
Young rider
« on: 27 March 2013, 08:32:33 pm »
best place to buy a service kit or is it best to buy it each bit?
Re: service for my 98 fazer
« Reply #1 on: 27 March 2013, 08:48:04 pm »
Do one thing at a time, keep a log of what you've done for future reference, then move on to the next thing.
It's easier to keep a check on things that way.
Young rider
« Reply #2 on: 27 March 2013, 09:17:46 pm »
Unfortunately there no service history but from the looks off things the owners look after it as its done 27000 miles and still have the original down pipes. I just want too keep the maintenance up to date and not run it in to the ground.
I was planning to do a oil, oil filter, plugs and filter change.
Then give the exhaust a coat of paint and check all fluids grease and clean everything as it's my daily commute.
packie
« Reply #3 on: 27 March 2013, 11:29:39 pm »
If you just bought the bike, that's what I would do too for peace of mind even if the last owner said they did it. If you are replacing the air filter, get a K&N one.
While the oil is draining, do the plugs and while you are at it, check and clean the chain. Adjust your tyre pressures too and that's all the basics done and you are ready for road.
If you set aside an hour on each weekend, You can tip away with other little stuff. Download the service manual or the Haynes manual from the website here and you can check through all the other periodic maintenance to do.
