Date: 06-05-26  Time: 04:40 am
Author Topic: silicone grease  (Read 5273 times)
dickturpin
silicone grease
« on: 23 March 2013, 06:55:44 pm »
anyone use silicone grease......now there's an invitation to post random uses.....and if so, what for? :rolleyes
wezdavo
Re: silicone grease
« Reply #1 on: 23 March 2013, 07:01:03 pm »
Yes, on o-rings for my air rifles....
Grahamm
  • Global Moderator
Re: silicone grease
« Reply #2 on: 23 March 2013, 08:26:31 pm »
Silicone grease? No.
I do sell Silicone Lube, however...  ;)
Kosmic Kartman
Re: silicone grease
« Reply #3 on: 23 March 2013, 08:26:57 pm »
Visor seals on my crash helmets and window seals on my car.
dickturpin
Re: silicone grease
« Reply #4 on: 23 March 2013, 09:07:23 pm »
I was watching a youtube vid recently and someone used it on caliper slider pins. I have some cera-tec ceramic grease for that
but wondered if silicone grease would be better?
Chris
Re: silicone grease
« Reply #5 on: 23 March 2013, 09:16:38 pm »
My dad and I have used it for a long time to protect electrical connections/fuse boxes etc. Pretty simple, break open the connector, stick in some silicon grease, clip it all back together, has preserved a lot of connectors that would have rotted. Maybe not so much a problem for you guys but in Shetland there is so much salt in the air that everything rusts if it isn't protected.
Chris
ade the blade
Re: silicone grease
« Reply #6 on: 23 March 2013, 09:19:15 pm »
used it on slider pins etc for years.....very kind on rubber !! most normal greases are petroleum-based which `dissolve` rubber over time. hth
Slaninar
Re: silicone grease
« Reply #7 on: 25 March 2013, 03:04:12 pm »
Seals of torch-lights. It's gentle on the rubber and doesn't ruin electrical contacts.
Ebme Geek
Re: silicone grease
« Reply #8 on: 25 March 2013, 04:40:34 pm »
contact seals, o-rings, dynamic seals, electrical connectors, ....  brain goes blank, but all over the place
very good smeared inside the ends of coolant hoses, helps seal them, slows down inevertable corrosion and helps getting pipe off next time
Excellent stuff     8)
Raymy
Re: silicone grease
« Reply #9 on: 27 March 2013, 07:13:45 pm »
Good stuff, if a little resistive.  It stays tho, cos the water based ones mean constant re-application. I hear grapeseed oil is good tho
gs_intruder
Re: silicone grease
« Reply #10 on: 01 April 2013, 01:32:30 pm »
Silicon grease is incredible stuff - buy the best quality stuff in bulk, like this:
http://www.ebay.co.uk/itm/310395680423?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
and also buy a couple of large veterinarian syringes like this:
http://www.ebay.co.uk/itm/151015592667?ssPageName=STRK:MEWAX:VRI&_trksid=p3984.m1423.l2661
Take out the plunger and you can pack the grease into the syringe quite easily, and the plunger will squeeze it through very effectively.
The proper quality stuff (not the waterbased 'personal' products  :eek ) is completely resistant to diesel, petrol, water, salt water, oil of any sort, detergents, soaps, etc. and will protect electrical connections for decades with one application. It is also entirely safe with rubber, plastic, metal (steel, alloys, etc.) and is unaffected by heat, cold, humidity, etc.
Two warnings:
1. Don't get any on your clothes because NOTHING will wash it out, and don't get it on the seat or grips etc. of your bike because they will stay slippery for a very long time.
2. Don't use it on battery terminals, because battery terminal corrosion isn't neutralised by it at all - better to use a petroleum based grease for that (like Vaseline).
If it does get anywhere you don't want it then you will need to rub it off with dry rags, making sure not to get it anywhere else...
I wouldn't be without it in the garage - use it on bikes, outside door locks (pack the inside of the lock and it will never rust or stick again), cars, generators, lawnmowers, the rubber rings on watch casings, waterproof camera casings, etc.
evesdad
Re: silicone grease
« Reply #11 on: 01 April 2013, 01:39:19 pm »
Use it all the time in work, mostly on "o"rings. Some things just won't slip in without it :rolleyes
Chris
Re: silicone grease
« Reply #12 on: 01 April 2013, 02:33:18 pm »
Thanks gs_intruder, like I said, my dad and I use it all the time ;)   :D
Welcome to the forum too! get up an introduction thread, you can use the pics from mine if you want  :lol
http://foc-u.co.uk/index.php/topic,6136.0.html
Chris
