Date: 24-04-26  Time: 14:00 pm
Author Topic: swing arm bearings  (Read 3473 times)
sadlonelygit
swing arm bearings
« on: 10 March 2013, 01:10:01 pm »
anyone got the bearing numbers to hand for these little blighters (not the sussie linkage, the actual swing arm) so i'm not bike less for too long waiting for whispered promises to be delivered :rolleyes
TIA
bludclot
Re: swing arm bearings
« Reply #1 on: 10 March 2013, 02:15:06 pm »
main bearing - ta2525z
small bearing - ta1715z
tko part numbers.
« Reply #2 on: 10 March 2013, 06:17:08 pm »
Try Mark at Marksman bearings http://www.bikebearings.co.uk/. He has all the bearings you need in bike specific kits.
He does a full set of swinging arm bearing and seals, I bought the collars/sleeves from Yamaha, but got the rest here. Excellent to deal with
http://shop.marksman-ind.com/fzr1000--fzs1000-fazer-linkage-bearing--seal-kit-10364-p.asp
sadlonelygit
« Reply #3 on: 10 March 2013, 06:37:17 pm »
just the bearings i don't want!
« Reply #4 on: 10 March 2013, 08:29:56 pm »
Misread the post
Marksman has those ones also, common enough bearing (early R1, XJR 1200, 1300, early R6 and FZ6)
http://shop.marksman-ind.com/ta2525z--25x33x25mm-2161-p.asp
Out of curosity is it definitely the swinging arm ones that are giving trouble? The swinging arm main bearings rarely give trouble and when they do it is usually due to heavy handed power hosing or missing end capse specially from the right hand side and/or sitting outside for long periods uncovered on the sidestand, ?
sadlonelygit
« Reply #5 on: 10 March 2013, 09:39:13 pm »
Guilty of the last one.
Had an advisory for them last MOT and i think they were being lenient.
Mine spends a lot of it's time on the back wheel as well, which doesn't help
bludclot
« Reply #7 on: 10 March 2013, 10:08:09 pm »
the ebay link directly above is for the small bearing pair that sits on the underside of the cross brace that the 'dog bones' attach to. the yamaha part number for the main bearing is 93315-42523. an ebay link to these:-
http://www.ebay.co.uk/itm/YAMAHA-XJR1300-XJR1200-YZF-FZS-Swing-arm-Bearings-x2-93315-42523-TA2525Z-/380596317643?pt=UK_Motorcycle_Parts&hash=item589d4eedcb
marksman supplied me with all the swing arm bearings, 4 in total,  for around £30 posted when i changed mine.
« Reply #8 on: 11 March 2013, 12:06:03 am »
That would not trouble them, they are designed for that :thumbup
